Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
necesito el bios de lenovo ideapad 3 15ALC6 SERIE PF3LNFJS RYZEN 3 GRACIAS
I need the BIOS for the Lenovo IdeaPad 3 15ALC6 PF3LNFJS RYZEN 3 SERIES, THANKSComment
Originally posted by tecnobosq
LENOVO ideapad 3
15ALC6
N/S : PF3LNFJS
Type 82KU
Chip de la bios: GigaDevice 25LR128DSIG
esta es la informacion mas completa
Every donation made will go towards server fees and maintenance costs.Comment
hi
i followed tutorials and tried everything i could but i had no luck
i replaced dmi from old bios to new one but somehow it didnt work and i cant find where am i wrong
could you please do it for me the right way?
LENOVO IDEAPAD 3 15ALC6
HS461&HS561&HS761 NM-D521
REV: 3.0
MTM: 82KU00WCAK
MO: PF9XB2C18011
S/N: PF49R008
Attached FilesComment
hi
REV: 3.0
MTM: 82KU00WCAK
MO: PF9XB2C18011
S/N: PF49R008Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi.
My Lenovo did not start and stopped giving video. I removed the Winband 74M12JWSIQ chip and the programmer shows it as W25Q128FW [1.8V]. I made a backup copy of the BIN but I can't find a BIN that works.
Can you repair the copy of the BIN file?
Lenovo ideapad 3 15ALC6
2021 - 10 -26 Rev. 3.0
MO: PF9XB2218139
MTM: 82KU00NHAR
S/N: PF3KHRQ9Attached FilesComment
Hi.
MO: PF9XB2218139
MTM: 82KU00NHAR
S/N: PF3KHRQ9Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
can you maybe explain which parts of the BIOS you need to transfer from the dump to the new one to transfer the DMI info (considering V15 G2-ALC)? Also I'm very much interested in how to decrypt the info like you did in the picture.
Kind Regards,
tandooriComment
https://www.badcaps.net/forum/troubl...-dmi-decrypter
DMI, as peste and others mentioned here is from 1000 to 2FFF, 8192 bytes. Search for text LENV----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
there is a Lenovo DMI decrypter in this forum
sorry, I did not find that info although it's on the same page. Well, thanks anyway for repeating it. About the decryptor: I use Linux, so I might try WINE to use it, since it's only an exe file and the source code calls Windows.h headers, which implies that it is not easily portable to Linux. Thanks for that though, also.
Kind Regards,
tandooriComment
Yo, I have this backup of the bios done with "SctWinFlash64.exe" before flashing,
IdeaPad 3-15ALC6 Laptop - Type 82KU, rev 3 board
S/N: PF34TEHD
I'm sure, there are no reading errors, as I have done two readings and they have the same data
Can I use this backup to make a new bios following the #4 post?
Or flash directly this bios?
Anyway I have a ch341a and a raspberry pi 5, the raspberry pi 5 is better suited for this right?Attached FilesLast edited by FachiroDiStriscia12; 12-30-2024, 08:52 AM.Comment
S/N: PF34TEHD
you have everything you need at post #56...
Sorry maybe I'm dumb, but post x56. doesn't contain any instruction and for some reason it does cite itself.
Anyway I have made this bios file removing the headers and changing the dmi data, is it correct?Attached FilesComment
what didn't you understand??write the bios on the chip from post #56..you also wrote the DMI interval there...what's the problem?...the bios is ok...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by Marc97hello there,, anyone who can help us to have bios for LENOVO
HS461 HS561 HS761 NM-D251 REV 2.0
I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
i attached the .CAP may you can help us also to trim it.....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
