Hs461 hs561 hs761 nm-d521 rev 2.0 2020-12-11 bios plz
Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
Tags: None
Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
IdeaPad 3-15ALC6 Laptop - Type 82KU
PF2WA834Attached FilesPremium supporters get full download access and other benefits.
Bios + DMI .
DMI (serial number etc) 1000 - 2FFF .
Add your own DMI using a hex editor or using the CopyDMI guide -> https://www.badcaps.net/forum/showthread.php?p=1214739 and this script -> https://www.badcaps.net/forum/showpo...42&postcount=2
You can use this guide to extract the bios from the support page if you want a different version ->
https://www.badcaps.net/forum/showthread.php?t=80861 .Its one of the newest phoenix bios,so the header needs cutting/deleting from 0-31F (Length 320)Attached FilesPremium supporters get full download access and other benefits.
Hello, I share a dump extracted from a working nm-d521 board.Attached FilesPremium supporters get full download access and other benefits.
I need HV461 & HV561 NM-D522 rev.2 bios bin please.Comment
the laptop does power up & CPU get hot, but no screen out put.Comment
s/n: PF3LVFDG
Lenovo V15 G2 ALCAttached FilesPremium supporters get full download access and other benefits.
Here's your New bios file, it's a virgin bios from Lenovo with your DMI so it should works fine.
Next time find your device thread or create your own.Attached FilesPremium supporters get full download access and other benefits.
Please help me with my dump
s/n: PF41N66D
Here's your New bios file, its a virgin file from Lenovo with your DMI.Attached FilesPremium supporters get full download access and other benefits.
Post the bios backup from your own bios chip on the motherboard. Post it in a zip or rar as an attachment, don`t post external links or 7z files.Click on the "Go advanced" button, then "Manage attachments"
.Last edited by SMDFlea; 03-03-2023, 02:38 AM.Comment
Please help me with my dump.
My device is a lenovo ideapad 3 15ALC6
S/N: PE08SZTZAttached FilesPremium supporters get full download access and other benefits.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
by Marc97hello there,, anyone who can help us to have bios for LENOVO
HS461 HS561 HS761 NM-D251 REV 2.0
I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
i attached the .CAP may you can help us also to trim it.....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by TrademarkHello everyone,
I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
This is NOT a BIOS password removal request.
I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
Laptop Information- Model: Acer Predator Triton 16 PT16-51-99GL
- Motherboard: DA0ZQDMB8AE Rev. E
- Main SPI flash: Winbond W25Q256JVEN (32MB)
- Secondary
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by Darksands[SOLVED]
Laptop: Dell Pro 14 Plus, PB14250
Motherboard: PWB CMF34, Rev (A00).
Service Tag: 3YLQ8F4.
CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
BIOS Flash Chip: Winbond 25R512NWEQ.
BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...-
- Loading...
