Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • danito
    • Jun 2016
    • 1068
    #161
    Originally posted by Keroro Gunsou
    hello sir, good day, my Lenovo 3 Ideapad 14ALC got bricked. only the ESC and CAPSLOCK and power button lights up, no display. can this bin file help?what to do with the bin file?ill be glad to donate if you could help me thank you
    read the rules..https://www.badcaps.net/forum/troubl...before-posting
    post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
    • Keroro Gunsou
      • May 2025
      • 5
      • Philippines
      #162
      i apologize the board model is NM-D521. i dont have any backup bios and the serial number is unknown due to missing back sticker sir
      • hoaca388
        Badcaps
        • Jan 2022
        • 12268
        #163
        What you need is not whether you have a spare bios but you need to buy an SPI programmer especially if you don't have the serial number.
        https://www.youtube.com/results?sear...mer+how+to+use
        • Keroro Gunsou
          • May 2025
          • 5
          • Philippines
          #164
          thank you i will give this a shot.
          • rramdandi
            • May 2025
            • 8
            • Indonesia
            #165
            good afternoon, i am having the same problem..
            Type: Lenovo v14 G2 ALC
            Sn: PF3AM7A3
            HV416&HV516 NM-D522 REV: 2.0
            Old Bios
            Badcaps Electronics Repair Forum & Schematic Search
            • LeoWing
              • May 2025
              • Ecuador
              #166
              Hello, good evening, dear engineers.
              My board is an HS461 HS561 HS761 nm-d521 rev 2.0 - from an IdeaPad 3-14ALC6 Laptop - Type 82KT.
              I appreciate any help.
              The problem arose when the battery died completely due to my carelessness.
              When I started it, I inadvertently shut down just as the Lenovo logo was loading.
              I tried every method I found on the web and in forums. Forced reboot, clearing residual power, disconnecting the internal battery. Nothing worked. Then I bought the ch341a programmer and used a clean copy of the BIOS update.
              GLCN63WW using the UEFI TOOLS tool, I extracted the raw file from the body and followed the steps in other forums with the programmer to read, clean, erase, program, and verify the process.
              It still doesn't work.
              Unfortunately, I didn't create a backup of my original BIOS due to lack of knowledge.
              I don't know what else to do. The laptop turns on the power button light and stays that way indefinitely.
              And if I disconnect the internal battery and the BIOS battery and press the power button, the LED keeps blinking indefinitely.
              Please help. I think this forum is the only hope I have left.
              • peste
                • 13421
                • ROMANIA
                #167
                you have everything you need at post #52..
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..
                .here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​
                • Keroro Gunsou
                  • May 2025
                  • 5
                  • Philippines
                  #168
                  hello sir, im back i bough a programmer and i was able to extract the original bios, i attachef it here. may i know what is next thing to do?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12268
                    #169
                    • Keroro Gunsou
                      • May 2025
                      • 5
                      • Philippines
                      #170
                      Currently selected: W25Q128FW [3.3V] 128 Mbits, 16 Mbytes
                      Current programmer: CH341 Black
                      19:24:28
                      Erasing memory...
                      Success
                      Execution time: 00:00:31.745
                      Done
                      CRC32 = 0x30582F15
                      19:25:17
                      Programming memory(verifying)... Main Memory
                      Success
                      Execution time: 00:03:28.069
                      You sir are a genius!thank you very much, my laptop is alive again! ill be donating as promised. by the way, i also have a bricked access point (TP LINK CPE605) it only turns on but not operating, can this technique be applied as well?like reflashing the chip inside?
                      • LeoWing
                        • May 2025
                        • Ecuador
                        #171
                        .here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                        Hola.
                        Buena noche.
                        O sea que solo con el archivo glcn52ww.bin podria revivir el portatil?
                        No nesecito preparar el archivo bios como lo he visto en otras entradas?
                        Por favor una aclaracion.
                        Recuerdo que lastimosamente no pude salvar el archivo original.
                        Hello.
                        Good evening.
                        So, just using the glcn52ww.bin file could revive the laptop?
                        Don't I need to prepare the BIOS file, as I've seen in other posts?
                        Please clarify.
                        I remember that unfortunately I couldn't save the original file.
                        • peste
                          • 13421
                          • ROMANIA
                          #172
                          write it as it is...if you write it correctly and the problem is from the bios it should work...
                          • ub6ib969
                            • Jul 2010
                            • 200
                            #173
                            hi everyone, got a lenovo ideapad IdeaPad 3-14ALC6 Hs461 hs561 hs761 nm-d521 rev 2.0 2020-12-11 motherboard. I do not have serial number, it has been rubbed off, however the unit does turn on but does not post with blinking power button. I have attached the bios if anyone can assist that would be appreciated.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12268
                              #174
                              • ocean 11
                                • Jun 2025
                                • uk
                                #175
                                i need the bios of the above serial number
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12268
                                  #176
                                  What serial number ? Why ?
                                  • ub6ib969
                                    • Jul 2010
                                    • 200
                                    #177
                                    thank you guys got it work.
                                    • jonnel
                                      • Jan 2021
                                      • 12
                                      • phillipines
                                      #178
                                      hello can i request bios bin for IdeaPad 3-14ALC6 Laptop - Type 82KT
                                      this is my SN: PF3FSJY8
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post merged,,,next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                    • peste
                                      • 13421
                                      • ROMANIA
                                      #179
                                      you have everything you need at post #52...
                                      • norobert
                                        • May 2020
                                        • 10
                                        • argentina
                                        #180
                                        Bios please.
                                        I have a question. What do I need to modify or repair to make the corrupted file work?
                                        ideapad3 14 alc6
                                        sn PF3DX8CK
                                        Thanks!!!!
                                        • Marc97
                                          lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                                          by Marc97
                                          hello there,, anyone who can help us to have bios for LENOVO
                                          HS461 HS561 HS761 NM-D251 REV 2.0
                                          I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                                          i attached the .CAP may you can help us also to trim it.....
                                          12-03-2022, 05:51 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
