Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • m1ch43lzm
    • Mar 2019
    • 1126
    • Peru
    #181
    Originally posted by norobert
    Bios please.
    I have a question. What do I need to modify or repair to make the corrupted file work?
    ideapad3 14 alc6
    sn PF3DX8CK
    Thanks!!!!
    See the answer above your post, anyway here it is
    BIOS from post 52 with your DMI added
    • norobert
      • May 2020
      • 10
      • argentina
      #182
      Thanks soo much!!!
      • delija89
        • Jan 2024
        • Serbia
        #183
        Hello all again,
        I have a problem I think with bios. When enter bios i have MTM and Lenovo SN = INVALID and after few seconds then turn off.
        IdeaPad 3-15ALC6 Laptop - Type 82KU
        AMD Ryzen™ 5 5500U Processor
        Serial Number: PF3HNABF
        MTN: 82KU006LYA
        Motherboard: hs461&hs561&hs761 nm-d521 rev 3.0
        In attachment is BIOS.
        Best regards,
        Delija
        • peste
          • 13924
          • ROMANIA
          #184
          Originally posted by delija89
          Hello all again,
          MTN: 82KU006LYA
          Best regards,
          Delija
          you have everything you need at post #52...
          https://www.badcaps.net/forum/troubl...bios-plz/page3
          • Guaculo
            • Jul 2020
            • 7
            • US
            #185
            Hi, hope you are doing great.
            I need to flash BIOS on a Lenovo IdeaPad 3 (Takes power, keyboard backlight lights on for a second, power button blinks all time, rest of the keyboard keys stay put, CPU gets warm)
            15ALC6
            S/N: PC295HXH
            MTM: 82KU00YWUS
            Mfg Date: 2021/12/18
            Board: HS461&HS561&HS761 NM-D521 Rev: 3.0 2021-05-08
            Thank you very much.
            • Guaculo
              • Jul 2020
              • 7
              • US
              #186
              15ALC6
              S/N: PC295HXH
              MTM: 82KU00YWUS
              I followed the instructions on post 52 Pasted the block from 1000 to 2fff from old bios to new bios, but didn't work, laptop behaves the same. Attached is the file i flashed.
              • peste
                • 13924
                • ROMANIA
                #187
                The bios you posted is empty and only has 4Mb...it should have 16 MB...make a new copy and post again..
                • Guaculo
                  • Jul 2020
                  • 7
                  • US
                  #188
                  Thats what came out from the programmer from the original BIOS, maybe thats why it was bad? I flashed it with the new BIOS anyways so it is lost. Is there a way i can configure a new BIOS from the start?
                  • m1ch43lzm
                    • Mar 2019
                    • 1126
                    • Peru
                    #189
                    You selected wrong chip model MX25U3235F (that's what the file name says), the BIOS chip should have 25*128 on its name (16 MB)
                    Your first backup is full of FF FF FF .... the chip was not read properly or erased before
                    Try again, select the correct chip model, if you have a 74M12JW select W25Q128JW on your programmer software
                    Flash post 52 as is (select the correct BIOS chip model first), you don't have a good original backup to transfer the DMI from, Laptop should boot and display INVALID serial/MTM/model name so you have to use Golden Key to enter model/serial/MTM after laptop boots
                    https://www.badcaps.net/forum/troubl...r-bootable-usb
                    • Guaculo
                      • Jul 2020
                      • 7
                      • US
                      #190
                      I flashed BIOS from post 52 with W25Q128JW selected, but still same behavior from the laptop. I notice the power button starts flashing as soon as i press it, possible bad CPU?
                      • andellapietra
                        • Nov 2025
                        • Italia
                        #191
                        good afternoon, please help me. my BIOS is locked. after I merged it and write it back, the laptop turns on but the screen is black
                        Laptop model: Ideapad 3 15ALC6
                        MTM:82KU00WEIX
                        serial num: PF3RKDL2
                        • peste
                          • 13924
                          • ROMANIA
                          #192
                          MTM:82KU00WEIX
                          post the contents of the bios chip even if it is corrupted..
                          • andellapietra
                            • Nov 2025
                            • Italia
                            #193
                            Here are the device details:
                            • IdeaPad 3 15ALC6
                            • MTM: 82KU00WEIX
                            • S/N: PF3RKDL2
                            • Motherboard: HS461 & HS561 & HS761 NM-D521 Rev 3.0
                            I apologize, this is what happened. I’d like to understand how to proceed.
                            There was a Windows update that also updated the BIOS to version GLCN68WW, and from that moment the laptop no longer boots.
                            I need to flash the BIOS on a Lenovo IdeaPad 3 (it powers on, the keyboard backlight briefly turns on, the power button keeps blinking, the rest of the keys remain lit, and the CPU gets warm).
                            I’ve read the guides but honestly I understood very little—I’m not an expert.
                            I managed to trigger crisis mode and I tried flashing a few .bin files, but the USB drive only blinks for a moment and then stops. The fans spin up, but nothing else happens. I think I’m doing something wrong.
                            I tried downloading version GLCN52WW, extracted it, renamed the BIOS.cap file to BIOS.bin and placed it on the USB drive — still nothing.
                            Then I tried removing the header (resulting in an 8192KB file), saved it as BIOS.bin, but again nothing.
                            I also tried some .bin files posted by other users in threads about the same 82KU model, but no luck.
                            What else could I try?
                            • m1ch43lzm
                              • Mar 2019
                              • 1126
                              • Peru
                              #194
                              You need a hardware programmer to read the existing contents of the BIOS chip
                              BIOS chip is 1.8V, make sure programmer supports 1.8V chips otherwise you will damage it
                              • andellapietra
                                • Nov 2025
                                • Italia
                                #195
                                I don’t have a SPI programmer, and honestly I wouldn’t even know how to hook it up or read the current BIOS contents.
                                Is there really no way to overwrite the BIOS without reprogramming the EEPROM directly?
                                Can’t it be done using Lenovo’s crisis mode?
                                • jagg
                                  • Feb 2012
                                  • 31
                                  • Mexico
                                  #196
                                  Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
                                  Here's your New bios file, it's a virgin bios from Lenovo with your DMI so it should works fine.
                                  Next time find your device thread or create your own.
                                  Thanks !!
                                  • OsmGn32
                                    • Sep 2020
                                    • 9
                                    • TÜRKİYE
                                    #197
                                    Hey guys, ı wish you good days.
                                    I have a device. Device working with no problem on linux but not working on windows. Also when ı tried to see bios configuration device restarting. On bios ı cant see SN, could you help me about this problem?
                                    NM-D521 REV 3.0
                                    SN PF9XB2B25137
                                    MTM 82KU01YHTX
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      #198
                                      NM-D521 REV 3.0
                                      SN PF9XB2B25137
                                      MTM 82KU01YHTX
                                      post full name and model,...
                                      • OsmGn32
                                        • Sep 2020
                                        • 9
                                        • TÜRKİYE
                                        #199
                                        sorry about that, Also ı saw 0A3 key id is null too,
                                        Lenovo IdeaPad 3 15ALC6
                                        NM-D521 REV 3.0
                                        SN PF9XB2B25137
                                        MTM 82KU01YHTX
                                        • peste
                                          • 13924
                                          • ROMANIA
                                          #200
                                          NM-D521 REV 3.0
                                          SN PF9XB2B25137
                                          MTM 82KU01YHTX
                                          • Marc97
                                            lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                                            by Marc97
                                            hello there,, anyone who can help us to have bios for LENOVO
                                            HS461 HS561 HS761 NM-D251 REV 2.0
                                            I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                                            i attached the .CAP may you can help us also to trim it.....
                                            12-03-2022, 05:51 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
