Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • lucaabr3
    • Jun 2023
    • 5
    • ARGENTINA
    Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
    Originally posted by Vesko356
    See post #4.
    Not work for me, the bios of Lenovo 15ALC6 has 16 MB, Post 4 is for 8 MB Bios :/ Please help me
    • lucaabr3
      • Jun 2023
      • 5
      • ARGENTINA
      See post #4.
      My device IDeapad 15ALC6 Type 82MF has a 16 MB Bios, post 4 is for 8 MB Bios, doesn't work for me, please help
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        Try the file from Post #14.
        all donations are welcome,
        • lucaabr3
          • Jun 2023
          • 5
          • ARGENTINA
          It works!! Can I have a problem using someone else's serial?
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            It's always best that the device has the correct info, so I just moved your DMI from your dump file to the working BIOS from post #14.
            Now you shouldn't face any problem.
            • lucaabr3
              • Jun 2023
              • 5
              • ARGENTINA
              #26
              This one is corrupted, I believe my dump corrupted this part but the other one (for V15 G2) worked perfectly! thanks!
              • bladezru
                • Jul 2023
                • 7
                flash bios on lenovo ideapad 3 15ACL6
                i'm new here, so i hope im correct here.
                My lenovo ideapad 3 (Mainboard HS461&HS561&HS761 NM-521 REV2.0) is broken and i will try to flash the bios chip new. But my problem is, that i found only one chip called "winbond 74M12JWSIQ" is this the correct chip? Because normally all bios chips should be started with 25*** or i'm wrong?
                • hardware1
                  • Sep 2021
                  • 2946
                  • N/A
                  #28
                  Re: flash bios on lenovo ideapad 3 15ACL6
                  Yes, it's the correct chip, (16MB-1.8V).
                  • bladezru
                    • Jul 2023
                    • 7
                    Okay great thanks.
                    • bladezru
                      • Jul 2023
                      • 7
                      lenovo ideapad 3 15ACL6 bios request
                      Hello i already tried all the tutorials to create the bios by my own and also all the bios files which are in this forum, but still have a blackscreen. So i hope someone can create the bios for me and i will try again.
                      Its a lenovo ideapad 3 15ACL6
                      MO: PF9XB153151
                      MTM: 82KU0034GE
                      Rev 2.0
                      • hardware1
                        • Sep 2021
                        • 2946
                        • N/A
                        #31
                        Re: lenovo ideapad 3 15ACL6 bios request
                        MO: PF9XB153151
                        MTM: 82KU0034GE
                        Rev 2.0
                        Virgin BIOS with your DMI, try it.
                        • bladezru
                          • Jul 2023
                          • 7
                          thanks, but still not working.
                          Is maybe the chip broken, if i try to verify the chip then i get every time different memory address
                          HTML Code:
                          Verify memory...
                          Verification error on address: 00000296
                          Execution time: 00:00:00.033
                          Current programmer: CH341
                          19:53:11
                          Verify memory...
                          Verification error on address: 000000AE
                          Execution time: 00:00:00.031
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #33
                            Try NeoProgrammer V2.2.0.10 ---> https://www.badcaps.net/forum/showth...11#post1215111
                            Don't use a clip.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • bladezru
                              • Jul 2023
                              • 7
                              still the same address error, i will buy a new chip and try it again. Maybe this will fix it.
                              • migreen06
                                • Aug 2023
                                • 5
                                Hi! Will this work for my laptop, its a different type? If it does, where do I change the type and serial number?
                                IdeaPad 3-15ALC6
                                Type: 82ku
                                SN: PF2VDQ4T
                                MTM: 82KU003NUS
                                Mobo: HS461& HS561& HS761 NM-D521 2020-12-11 Rev:2.0
                                Thanks!
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  IdeaPad 3-15ALC6
                                  Type: 82ku
                                  SN: PF2VDQ4T
                                  MTM: 82KU003NUS
                                  Thanks!
                                  Read post #20
                                  • migreen06
                                    • Aug 2023
                                    • 5
                                    Read post #20
                                    I read literally every post, on every thread, that was even remotely relevant, which unfortunately, was hundreds. It got all jumbled up in my head.
                                    Post 20 says to read post 4, the copyDMI guide. It also says to remove the header but it's unclear if I remove the header from the "oldbios" AND the "newbios."
                                    The "newbios" is the bin file made after unpacking the Phoenix TDK file, mentioned in a different thread on this site? Does it matter that my original bios ("oldbios") is 16,384 kb and the "newbios" is 8,192 Kb? attached both.
                                    Sorry if these sound like stupid questions. Thanks for your help!
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #38
                                      Reading all related posts is not enough, you must try to understand all the information in that posts otherwise you just read some text which obviously is not very fruitful as you (and I) can see.
                                      Slow down - first of all old bios is needed for copying the DMI information in it - nothing more, nothing less, so all the modifying we must do is related to the new file i.e. new bios. Secondly if you try to read the guide more carefully you will see that you must remove the header from the bios.cap file extracted from the bios update executable downloaded from the manufacturer support page.
                                      That's right - after extracting the bios.cap file from the update executable we must cut it to have the new (virgin) bios dump, and after moving the DMI information from our old dump to it we have the finished file ready to be programmed to the bios chip.
                                      16,384
                                      Don't want to be rude but that's B.S. Both old and new file must be 16,384 KB each.
                                      Post #4 is about 41 version (GLCN41WW) of the bios, so first things first, the link for you to download this update executable is:
                                      https://download.lenovo.com/consumer...s/glcn41ww.exe
                                      Download the file, extract the bios.cap file from it, attach the file in your next post when ready, and we will continue to talk after that.
                                      • migreen06
                                        • Aug 2023
                                        • 5
                                        I didn't use GLCN41ww because that's a very old version. I used GLCN52WW.
                                        I figured it out. I was following the post about extracting TDK files and it says to select/copy 0-800000 but my chip is 16 not 8. So, I made the adjustment and got the DMI info in. So, I am ready to hook up my programmer. I was making it much more complicated than it needed to be.
                                        Thanks!
                                        • migreen06
                                          • Aug 2023
                                          • 5
                                          The flash worked fine but my issue still exists. I have a motherboard virus that apparently can"t be removed. Flashing the spi was the last resort. I guess I will be throwing away a laptop I bought less than 3 years ago.
                                          • Marc97
                                            lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
                                            by Marc97
                                            hello there,, anyone who can help us to have bios for LENOVO
                                            HS461 HS561 HS761 NM-D251 REV 2.0
                                            I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
                                            i attached the .CAP may you can help us also to trim it.....
                                            12-03-2022, 05:51 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
