lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    hello there,, anyone who can help us to have bios for LENOVO
    HS461 HS561 HS761 NM-D251 REV 2.0
    I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
    i attached the .CAP may you can help us also to trim it..
    • 21440
    Re: lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
    Please post the full laptop model number and serial
      • 21440
      Delete 0 - 31F (length 320) ,then select 0 - FFFFFF (Length 1000000) ,copy and save to a new file. Copy the DMI from your bios backup !
      • Marc97
        • Jan 2016
        • 189
        • Phillipines
        thank you sir,,,
        unit info,,, model name IdeaPad 3 14ALC6
        serial number PC20KGZ0
        • Marc97
          • Jan 2016
          • 189
          • Phillipines
          THANK you,,, update if finish,,,, MASTER
          MY FILE is 17. somthing MB
          i cant make it 16384 by this maybe i have made error understanding on saving on my hexedit
          • Marc97
            • Jan 2016
            • 189
            • Phillipines
            here is my back up,,, unit status no display,,, after winodws update as per client
            • hardware1
              • Sep 2021
              • 2943
              • N/A
              Here's your new file. it's a virgin file from Lenovo, I just moved your DMI.
              all donations are welcome,
              • Marc97
                • Jan 2016
                • 189
                • Phillipines
                thank you... i will update u soon,, for result
                • Marc97
                  • Jan 2016
                  • 189
                  • Phillipines
                  thanks you tested file... finish,, done,, thank you SMDFLEA,, &hardware1,,,, godbless,,,,
                  • jedireez
                    • Feb 2023
                    • Trinidad & Tobago
                    This saved my laptop, thanks very much...
                    • hardware1
                      • Sep 2021
                      • 2943
                      • N/A
                      You're Welcome.
                      • zonjay02
                        • Dec 2022
                        • Philippines
                        have same issue with my laptop. what bios programmer you used? getting verification error using ch341a programmer..
                        • hang-air
                          • Aug 2023
                          • Switzerland
                          Thank you so much, my Ideapad works again!!!
                          • hang-air
                            • Aug 2023
                            • Switzerland
                            BTW: I user CH341A programmer with 1.8V adapter and AsProgrammer (https://github.com/nofeletru/UsbAsp-flash/releases)
                            • Ismail Siraje Ittembe
                              Kampala Member
                              • Jan 2024
                              • 25
                              • Uganda
                              NEED HELP WITH THIS
                              serial number PF3907AT​
                              • peste
                                • 13183
                                • ROMANIA
                                Originally posted by Ismail Siraje Ittembe
                                NEED HELP WITH THIS
                                post the original bios of the laptop even if it is corrupted,​etc
                                  Kampala Member
                                  • Jan 2024
                                  • 25
                                  • Uganda
                                  here it is
                                  • peste
                                    • 13183
                                    • ROMANIA
                                    here it is
                                    you have everything you need at the #56.post..
                                    https://www.badcaps.net/forum/troubl...e3#post1848937
                                    • norobert
                                      • May 2020
                                      • 10
                                      • argentina
                                      Bios please.
                                      I have a question. What do I need to modify or repair to make the corrupted file work?
                                      ideapad3 14 alc6
                                      sn PF3DX8CK
                                      Thanks!!!!
                                      • Forest79
                                        by Forest79
                                        07-23-2023, 07:39 AM
                                      • survivalbloke
                                        Unable to extract bios file from Lenovo bios exectuable
                                        by survivalbloke
                                        I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                        Code:
                                        "innoextract 7wcn38ww.exe"
                                        it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                        The trouble I'm having is that I'm not getting the newly...
                                        06-12-2024, 07:55 AM
                                      • maanee11
                                        Help to get Lenovo BIOS bin file for Thinkpad T560
                                        by maanee11
                                        Hello Everyone,
                                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                        05-15-2022, 11:59 AM
                                      • survivalbloke
                                        Unable to extract Lenovo BIOS file from installer
                                        by survivalbloke
                                        I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                                        I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                                        How can...
                                        07-16-2025, 03:21 PM
                                      • pcwhiz24
                                        Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                        by pcwhiz24
                                        Model: Lenovo IdeaPad 3 14ADA05 81W0
                                        S/N: PF2BZS7D
                                        I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                        I already have a CH341A programmer...
                                        04-07-2025, 07:10 PM
