Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
Hello all again,
I have a problem I think with bios. When enter bios i have MTM and Lenovo SN = INVALID and after few seconds then turn off.
IdeaPad 3-15ALC6 Laptop - Type 82KU
AMD Ryzen™ 5 5500U Processor
Serial Number: PF3HNABF
MTN: 82KU006LYA
Motherboard: hs461&hs561&hs761 nm-d521 rev 3.0
In attachment is BIOS.
Best regards,
Delija
Attached FilesComment
you have everything you need at post #52...Hello all again,
MTN: 82KU006LYA
Best regards,
Delija
https://www.badcaps.net/forum/troubl...bios-plz/page3Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi, hope you are doing great.
I need to flash BIOS on a Lenovo IdeaPad 3 (Takes power, keyboard backlight lights on for a second, power button blinks all time, rest of the keyboard keys stay put, CPU gets warm)
15ALC6
S/N: PC295HXH
MTM: 82KU00YWUS
Mfg Date: 2021/12/18
Board: HS461&HS561&HS761 NM-D521 Rev: 3.0 2021-05-08
Thank you very much.Attached FilesComment
I followed the instructions on post 52 Pasted the block from 1000 to 2fff from old bios to new bios, but didn't work, laptop behaves the same. Attached is the file i flashed.Hi, hope you are doing great.
15ALC6
S/N: PC295HXH
MTM: 82KU00YWUS
The bios you posted is empty and only has 4Mb...it should have 16 MB...make a new copy and post again..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thats what came out from the programmer from the original BIOS, maybe thats why it was bad? I flashed it with the new BIOS anyways so it is lost. Is there a way i can configure a new BIOS from the start?Comment
You selected wrong chip model MX25U3235F (that's what the file name says), the BIOS chip should have 25*128 on its name (16 MB)
Your first backup is full of FF FF FF .... the chip was not read properly or erased before
Try again, select the correct chip model, if you have a 74M12JW select W25Q128JW on your programmer software
Flash post 52 as is (select the correct BIOS chip model first), you don't have a good original backup to transfer the DMI from, Laptop should boot and display INVALID serial/MTM/model name so you have to use Golden Key to enter model/serial/MTM after laptop boots
https://www.badcaps.net/forum/troubl...r-bootable-usbComment
by Marc97hello there,, anyone who can help us to have bios for LENOVO
HS461 HS561 HS761 NM-D251 REV 2.0
I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
i attached the .CAP may you can help us also to trim it.....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
