bios x512dk
  • mojtabapackzaman
    • Jul 2019
    • iran
    bios x512dk
    asus x512dk bios please
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: bios x512dk
    try this dump for asus x512dk
    Last edited by SMDFlea; 07-01-2022, 03:30 AM. Reason: bios password,removed attachment
    • nilantha maduranga
      • Aug 2012
      • 17
      • sri lanka
      Re: bios x512dk
      aboumohamed password please
        • Aug 2012
        • 17
        • sri lanka
        Re: bios x512dk
        PASSWORD SIMPLE LETTER - islam
        • ngohieu
          • Jul 2021
          • viet nam
          Re: bios x512dk
          What is your password ?
          Islam is incorrect
            • 20855
            Re: bios x512dk
            Islam is incorrect
            The above file has been removed. Here it is without any password .
            • agent_dn
              • Apr 2016
              • 6
              • vietnam
              Re: bios x512dk
              Bios From Asus Site
              mainboard code X512DK rev 2.1
              paper stamps code X512DA
              • mferna14
                • Jun 2018
                • 1020
                Re: bios x512dk
                Hi all., can anyone do a cleanup for this Original BIOS dump file. With this original file, I see the White LED on the LHS glow up but still when I press the ON/OFF button on the keyboard, it does not turn on the motherboard, no increase of amp on the amp meter. I tried other BIOS dumps on this thread & other related threads, but believe it or not, NONE of them worked, the LED does not even glow in all other dumps. Mine is an ASUS AMD RYZEN 5., & on the keyboard connector pin 30 (Assuming this is the ON/OFF pin) I get 2.9v, is this ok??? Motherboard Part # X512DX Rev: 2.1 ... Thank you
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11729
                  Re: bios x512dk
                  Look for stickers and QR codes on the motherboard to accurately identify your model.
                  • hardware1
                    • Sep 2021
                    • 2930
                    • N/A
                    Re: bios x512dk
                    Here's your New Bios, it's a Virgin Bios from ASUS with your DMI and Windows Key.
                    As @hoaca388 said before, see if you have any sticker on the motherboard contains (X512DA) or something else.
                    Also see if that Serial Number matching your Serial on the Laptop cover.
                    Serial Number: KAN0CV119744437.
                    all donations are welcome,
                    • mferna14
                      • Jun 2018
                      • 1020
                      Re: bios x512dk
                      Thank you so much @hoaca388 @hardware1... attached are the photos of the only sticker at the back of the motherboard for you'll to review. Kindly view them.
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        Re: bios x512dk
                        Try the file in post #10 it should works fine, otherwise we can try an older version to be more precise.
                        • mferna14
                          • Jun 2018
                          • 1020
                          Re: bios x512dk
                          Just now I programmed the new BIOS on post #10, It did not work. With this BIOS version I do not get the 3.3V & 5v, all gone. But with the Original one which I posted in #8, I do get 3.3V & 5V, the LED glow WHITE but still when I press the ON/OFF button on the keyboard, the motherboard does not turn on. Where is the Older Version please inform me, I will surely try that one. Thanks for the help.
                          • hardware1
                            • Sep 2021
                            • 2930
                            • N/A
                            Re: bios x512dk
                            Try.
                            • mferna14
                              • Jun 2018
                              • 1020
                              Re: bios x512dk
                              Thanks., I will try right now & inform you, & now I found out that I have to program the dump on a 1.8V BIOS. help appreciated @hardware1
                              • mferna14
                                • Jun 2018
                                • 1020
                                Re: bios x512dk
                                @hardware1 thanks for the help, post #10 worked fine. Only my fault, I was programming on a 3v BIOS chip whereas I had to use a 1.8V chip. Once I got this chip, programmed the Bin Dump & all worked fine without any problem, really appreciate your help.
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  Re: bios x512dk
                                  You're Welcome @mferna14, glad for you.
                                  • Patriarxis
                                    • 18
                                    • Greece
                                    Re: bios x512dk
                                    Hello .
                                    This is my original bios but with this one i have no start up. i have all the voltages on the coils exept cpu coils and white led. i belive that is corrupted from bios update.
                                    The serial of the laptop is KAN0CV11N581438.
                                      • 20855
                                      Re: bios x512dk
                                      Originally posted by Patriarxis
                                      Hello .
                                      Post a picture of the barcode sticker,like the one at posts ##11 and #12
                                      • Patriarxis
                                        • 18
                                        • Greece
                                        Re: bios x512dk
                                        Here is it.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Anchar777
                                          ASUS P1412CE need BIOS DUMP
                                          by Anchar777
                                          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                          06-26-2025, 03:39 AM
