Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • rex98
    • Feb 2023
    • 1277
    • Mandaue CEBU, Philippines
    #361
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by rex98
    kindly unlock it please it has bios password and absolute swat lock.
    kindly clean the main dump where i can put manually the DMI via MPM tool please. i attached the Main and EC dump.
    it says in boot hp wolf security.
    SN: 5CG2237FML
    why is my dump so diffrent from other dumps here? i tried file compare i copy paste the changes in the unlocked and locked ones i downloaded here and it doesn't work. i read 5 times the main and EC dump its all identical just to make sure. can someone send here where is the DMI block address? i wanna try put my DMI in unlocked bios from this forum.
    • hyditech
      • 272
      • nigeria
      #362
      hello,i have hp elitebook 850 g8 11th Gen...it has password..
      please which of the chip has the password..
      so that i will know the chip i will copy
      thanks..
      very urgent please
      • farouk_1994
        • Mar 2021
        • 392
        • algeria
        #363
        thanks..
        very urgent please
        the chip under the motherboard
        • farouk_1994
          • Mar 2021
          • 392
          • algeria
          #364
          SN: 5CG2237FML
          Try it than replay
          • hyditech
            • 272
            • nigeria
            #365
            Alright boss... i will copy it and send it here...
            thank you and may God bless you boos..
            i will post the dump,thank you.
            • hyditech
              • 272
              • nigeria
              #366
              here my dump with password
              please help me clear password
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #367
                Read the rules before posting:
                Do NOT hijack threads.
                Become a Badcaps supporter
                Thanks to all supporters.
                • Hema2010h
                  • Jun 2023
                  • Usa
                  #368
                  attached the bios and ecbios for 850 g8
                  it has swat lock , can you please unlock it?
                  840 not 850 sorry, typo
                  • hyditech
                    • 272
                    • nigeria
                    #369
                    Alright noted......I only reply to messsage..
                    because it my first time doing 850 g8..
                    so i wanted to know the right chip to read..
                    thanks boss.. I have noted that warning...
                    i was unable to do it myself that was why i need help.
                    • kulokutoys
                      • Jun 2010
                      • 132
                      • Phillippines
                      #370
                      please be patient on this patch, it will take 5 o more mins for 1st boot up then will restart for a couple of tries. restore factory default on bios then reformat the drive.
                      • Marc97
                        • Jan 2016
                        • 189
                        • Phillipines
                        #371
                        Originally posted by hoaca388
                        Try :
                        good day
                        also hp elitebook 840 g8,, lock on bios wolf lock,,,
                        after i use the 2 files above cant detect ssd
                        maybe you can hel us i attached my original files with lock
                        both 32mb
                        unit serial num 5CG211456L
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #372
                          Originally posted by Marc97
                          good day
                          both 32mb
                          try
                          • elmaspro
                            • Jun 2023
                            • 7
                            • España
                            #373
                            Finally I extracted the two chips with a heat gun.
                            Before that use heat pistol, the one on the top of the MB, I tried to extract it with a soldering iron but it went wrong. The chip is broken and the MB has damaged tracks
                            Is it possible to buy a chip and reprogram it? Chip: Windbond 25Q256JVEN
                            I have also damaged the MB, I think I can fix the tracks and Pads.
                            Attached screenshots.
                            Best regards.
                            • Marc97
                              • Jan 2016
                              • 189
                              • Phillipines
                              #374
                              Flash only this file.
                              This file is good i inlock bios paassword.. But after a fewdays of use the unit turns into swat lock.. What field in bios do i need to off if i reflash again.. Or do i need to find new bin file
                              • Marc97
                                • Jan 2016
                                • 189
                                • Phillipines
                                #375
                                Originally posted by qayyum786
                                try
                                Thank you.. I will try this..
                                • Blallowinformatic
                                  • Mar 2020
                                  • 27
                                  • México
                                  #376
                                  Can you help me unlock my HP EliteBook 840 G8 please?
                                  Both ram-side and ece-side bin files inside the .rar
                                  Motherboard model 6050A3426501-MB-A02
                                  S/N: 5CG2107WBM
                                  Prod ID: 35Y57LT#ABM
                                  Build ID: 21WWCVET601#SABM#DABM
                                  Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEmwn7nVnpq.3B
                                  Thanks in advance for the time.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #377
                                    S/N: 5CG2107WBM
                                    • xplodpg
                                      • Oct 2016
                                      • 30
                                      • Polska
                                      #378
                                      Hi. Please unlock my HP 840 G8
                                        • 20855
                                        Use RCUnlocker on the 16MB dump.If you read through the rules you`ll find it.
                                        • xplodpg
                                          • Oct 2016
                                          • 30
                                          • Polska
                                          #380
                                          RCUnlocker unlocker my bios but if start bios i have error "EndPoint Security Controller Problem"
                                          Can you help mi?
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
