Extract bios password from EliteBook 840 G8 Bios dump, possible?
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    #141
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by aurelmdx
    hi . please help unlock bios, tried everything and nothing helps. Thanks
    Try this one with your EC chip (orig2), put your main chip Back (orig) and let me know what will happen.
    all donations are welcome,
    • dhan
      • Jun 2018
      • 134
      • hp
      #142
      I've tried the AA 55 3F to 3C
      still the absolute persistence is active.
      please help
      • volinakis
        • Jan 2021
        • 2734
        • N/A
        #143
        please help
        at 1st boot restore factory defaults.
        • dhan
          • Jun 2018
          • 134
          • hp
          #144
          I've done the restore to factory.
          iT seems still missing something.
          • volinakis
            • Jan 2021
            • 2734
            • N/A
            #145
            try again with this one. And reset Security settings.
            • dhan
              • Jun 2018
              • 134
              • hp
              #146
              Thank you!
              • dhan
                • Jun 2018
                • 134
                • hp
                #147
                I've try to remove the BIOS admin password.
                after flashing, the laptop fan spins, keyboard lights on and off.
                then no display.
                please check if what is wrong.
                I attached the bin file of password lock and password remove
                Thank You
                • Ali5914
                  • Dec 2020
                  • 48
                  • India
                  #148
                  Re: hp elitebook 840 g8 bios password
                  Originally posted by Vesko356
                  Here you are:
                  Hello sir, i love learning new things regarding bios modding. I compared your new bin with the old one. Everything is same apart from first padding. If you do not mind , can you please explain what did you replace in padding. Thanks in advance.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11799
                    #149
                    then no display.
                    Thank You
                    There's nothing wrong with your file.
                    • bilen
                      • Aug 2014
                      • 638
                      • istanbul
                      #150
                      6050a3216701-mb-a01 bİos
                      Hp 850 G8 Bios password
                      its ec file 25q80 1mb
                      bios is 32 mb :
                      please unlock password.
                      not : HP UNLOCKER AND rc unlocker not working
                      • hardware1
                        • Sep 2021
                        • 2936
                        • N/A
                        #151
                        Re: 6050a3216701-mb-a01 bİos
                        ec file : please unlock password.
                        not : rc unlocker not working
                        Wrong chip or Wrong way to read the chip. you need to read the chip again, also upload the EC chip.
                        • bilen
                          • Aug 2014
                          • 638
                          • istanbul
                          #152
                          And bİos
                          • bilen
                            • Aug 2014
                            • 638
                            • istanbul
                            #153
                            no it's all true
                            these are all chips
                            • hardware1
                              • Sep 2021
                              • 2936
                              • N/A
                              #154
                              And bİos
                              Try this one and let me know the results.
                              In the first boot, go to the bios setting and disable all the security options.
                              If this method didn't work, upload your other chip (EC chip) it could be 16 or 32MB.
                              • Fighter
                                Veteran Member
                                • Jul 2017
                                • 36
                                • Pakistan
                                #155
                                HP Elitebook x360 830 G8 Bios Password .....i'm uploading bottom file U368
                                need Help Thanx in advance..
                                Bios Password and shows this error also...
                                  • 20990
                                  Post your reqest in a 830 G8 thread not in this 840 G8 thread.
                                  • Fighter
                                    Veteran Member
                                    • Jul 2017
                                    • 36
                                    • Pakistan
                                    #157
                                    ok sir thanx i'll..
                                    • bhatt
                                      • Dec 2015
                                      • 92
                                      • pakistan
                                      #158
                                      Your bios UNLOCK
                                      REPLY ME
                                      • smallvhin
                                        • Jul 2015
                                        • 182
                                        • philippines
                                        #159
                                        Master pls help me to remove password
                                        and Internet swat lock.🙏 TIA
                                        • hardware1
                                          • Sep 2021
                                          • 2936
                                          • N/A
                                          #160
                                          Here are your Unlocked files. program the both chips together, in the first boot go to bios menu and disable security options (Default).
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            Today, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
