Dell G5 15 5500 bios needed
hello every one
i have dell g5 15 5500
mainboard Selek mlk n18E 19753-1
Service Tag: deleted from the computer cover, and I don't know how to get it from the dump
Please clean my file, no displayComment
try thisAttached FilesComment
Dell G3 3500
ST: B69ZH3
Motherboard: SELEK MLK N18E FJT96$LA
Sup friends, my notebook turns on and gives video only when reach windows, i cant acess bios even on external video. And fan is always on full mode. IDK if the bios is original but i will post here the backup. Can someone help me please?Attached FilesComment
try https://www.badcaps.net/forum/troubl...92#post3599592Dell G3 3500
ST: B69ZH3
Sup friends, my notebook turns on and gives video only when reach windows, i cant acess bios even on external video. And fan is always on full mode. IDK if the bios is original but i will post here the backup. Can someone help me please?Comment
							Channel: BIOS Requests ONLY!
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
			by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
 - Loading...
