Dell G5 15 5500 bios needed
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    #81
    Re: Dell G5 15 5500 bios needed
    Write your Device Service Tag.
    Originally posted by Alaa El den
    4vym563
    I wrote this Quote for "dariusgc", why you give me your Service Tag! what's your device problem and where is your Backup Bios?
    all donations are welcome,
    • dariusgc
      • May 2020
      • 45
      • Lithuania
      #82
      write your device service tag.
      1hltc63
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        #83
        Originally posted by dariusgc
        1hltc63
        Here are you New Bios, try it and give me results.
        • dariusgc
          • May 2020
          • 45
          • Lithuania
          #84
          Nope, it doesn't work.
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            #85
            Doesn't work means No Power, No Image or what?
            Also what was your main problem?
            • dariusgc
              • May 2020
              • 45
              • Lithuania
              #86
              Thanks for your files, but i think there is power issues on the motherboard. Cause there is only few blinks on led near power jack.
              • trepachka
                • Oct 2022
                • 457
                Perhaps someone can verify that I am having bad BIOS issues. Currently, the BIOS is password protected by 8FC8 password. I have the password for it. However, on every boot, the keyboard starts flashing different colors (I think that's normal), the screen that is supposed to be prompting me to enter the password gets distorted. I get a window with its message cut off at different times. May be on my 10th attempt I get the 8FC8 window with full message and the box to enter the password in but the keyboard gets disabled, no keys work. External keyboard also does not work. However, I can do Ctrl-Alt-Del to reboot no problem. My thinking is if BIOS is bad, then you get random results like I am getting now.
                Can someone confirm it's the BIOS?
                Also, does the motherboard have a single or two BIOS chips? I am yet to take out the motherboard from the case.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12420
                  #88
                  All speculation is conjecture.
                  If your device has 2 bios chips, they will be located near each other (on Dell computers).
                  Solution: post your bios file here we will rebuild it so you can rule out the cause of the error caused by bios (since you already have the password, you don't need to delete the password in the new file)
                  ​https://www.badcaps.net/donate
                  • trepachka
                    • Oct 2022
                    • 457
                    I have attached the BIOS I extracted from both chips. I would appreciate if someone fixed it for me. It does have 8fc8 password lock on it and I do have the password for it. But if you can remove the password while at it, that would help me avoid doing this extra step. Thank you.
                    • trepachka
                      • Oct 2022
                      • 457
                      Can you guys, please rebuild the bios files I submitted in my previous response?
                      • paulyboy
                        • Mar 2020
                        • 130
                        • New Zealand
                        #91
                        dell g5 5500 bios clean please
                        Hi there, I ave a Dell g5 5500 that I would appreciate if you guys could clean for me.
                        Kind regards
                        Paul
                        • paulyboy
                          • Mar 2020
                          • 130
                          • New Zealand
                          #92
                          Re: dell g5 5500 bios clean please
                          attached
                          • hardware1
                            • Sep 2021
                            • 2949
                            • N/A
                            #93
                            Originally posted by paulyboy
                            attached
                            First thing don't choose (OTP), this will add some extra length to the file.
                            Second, we need your 16MB file also, in order to merge both files and Clean the ME Region.
                            • paulyboy
                              • Mar 2020
                              • 130
                              • New Zealand
                              #94
                              thankyou for your time, unfortuantely i have 3 backups only with the OTP and have since flashed a couple roms on here in hopes of fixing the issue.
                              I have added the 2 bios files if you can assist in anyway it would be awesome
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                #95
                                Here's your New BIOS, try it and let me know.
                                • judamex
                                  Active Member
                                  • Jan 2021
                                  • 186
                                  • Mexico
                                  #96
                                  Originally posted by hoaca388
                                  g5 15 5500
                                  This file Work For me, But Bios its too slow i can´t enter to edit and no boot freeze on del logo
                                  ST:7YM6003
                                  • Radio Operator
                                    • Jun 2016
                                    • 17
                                    • greece
                                    #97
                                    I would be grateful if you could send me the bios files for this machine.
                                    I tried all of the above and none of them worked.
                                    S/N: HW2XF63
                                    I attach the old bios.
                                    • trepachka
                                      • Oct 2022
                                      • 457
                                      I can post my old bios but I bricked it pretty bad. So, can someone post a generic BIOS for both chips (8Mb and 16Mb) I can use to flash the machine? Thanks.
                                      Service Tag# C3L7D63
                                      • Radio Operator
                                        • Jun 2016
                                        • 17
                                        • greece
                                        #99
                                        Dell G5 15 5500 Bios bricked after update
                                        Model P89F
                                        P89F003
                                        S/N HW2XF63
                                        Laptop was bricked after latest bios update. It has dual bios. I flashed many other files from another thread with no luck.
                                        • Radio Operator
                                          • Jun 2016
                                          • 17
                                          • greece
                                          #100
                                          Re: Dell G5 15 5500 Bios bricked after update
                                          Originally posted by Radio Operator
                                          Model P89F
                                          P89F003
                                          S/N HW2XF63
                                          Any update?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • 417731
                                            BIOS needed for Dell Vostro 3405
                                            by 417731
                                            Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                            Model: Dell Vostro 3405
                                            Tag:F0B1YF3
                                            CPU:Ryzen 3500U
                                            Thanks in advance
                                            07-06-2025, 06:48 PM
