PCH has been replaced I need an unconfigured me region.
Dell G5 15 5500 bios needed
Hi, I have a dell g3 "15-3500-860?" that turns on but no display, can you clean the bios for me please, unfortunately I no longer have the label on the cover.
But the motherboard model is 19753-1, 10 ème génération. i7. nvidia
I tried post 9 and 133 but it doesn't work the laptop lights up, flashes then turns offAttached FilesPremium supporters get full download access and other benefits.
1 PhotoLast edited by madjid911; 04-27-2024, 07:17 AM.Comment
Try a new oneHi, I have a dell g3 "15-3500-860?" that turns on but no display, can you clean the bios for me please, unfortunately I no longer have the label on the cover.
I have already looked, I have no shorts, the voltages are good, the battery charges well, the backlit keyboard lights up correctly, but no display, the shift key does not respond, I tried with an external screen, and I tried other rams, for me it probably comes from the bios but I tried many bios here nothing workedComment
remove all power sources adapter rtc, bettry, wirles Lan card press pwr button for 30 second chk with adapter to boot
if no image keep attach adapter and press pwr button to turn off and pres pwr button again to boot
power chocking also causes to no imageLast edited by qayyum786; 04-27-2024, 10:58 AM.Comment
that's what I did, but same result, I was lucky today to have another identical model laptop with HS processor, so I recovered the 3 eeproms but I didn't display, I no longer have the LEDs flashing but the shift key still does not respond, I suppose the bios of the other laptop were good so the problem does not come from there, so I swapped the two micro controller (KBC34 and STM32), but the result is still the same, yet I have all the voltages, I guess the processor or the graphics card must have a problem thenComment
Can you share those 3 eeproms ,they might help someone else https://www.badcaps.net/forum/troubl...15#post3217015
Did you clean the ME firmware before trying the biosComment
Yes I share the 3 original bios files, can you clean the Intel region for me so I can do one last try please
Did you clean the ME firmware before trying the biosAttached FilesPremium supporters get full download access and other benefits.
clean meAttached FilesPremium supporters get full download access and other benefits.
Hi friends
please i need Dell g5 15 5500 bios
MB:SELEK MLK N18E
19753-1
old bios sometimes work
service tag: 70R4563
please clean bios
i7 10th generationAttached FilesPremium supporters get full download access and other benefits.
1 PhotoComment
Dell G5 15 5500
Thẻ dịch vụ: 70R4563
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Channel: BIOS Requests ONLY!
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
