PCH has been replaced I need an unconfigured me region.
Dell G5 15 5500 bios needed
Hi, I have a dell g3 "15-3500-860?" that turns on but no display, can you clean the bios for me please, unfortunately I no longer have the label on the cover.
But the motherboard model is 19753-1, 10 ème génération. i7. nvidia
I tried post 9 and 133 but it doesn't work the laptop lights up, flashes then turns offAttached Files1 PhotoLast edited by madjid911; 04-27-2024, 07:17 AM.Comment
Try a new oneHi, I have a dell g3 "15-3500-860?" that turns on but no display, can you clean the bios for me please, unfortunately I no longer have the label on the cover.
I tried post 9 and 133 but it doesn't work the laptop lights up, flashes then turns offAttached FilesComment
I have already looked, I have no shorts, the voltages are good, the battery charges well, the backlit keyboard lights up correctly, but no display, the shift key does not respond, I tried with an external screen, and I tried other rams, for me it probably comes from the bios but I tried many bios here nothing workedComment
remove all power sources adapter rtc, bettry, wirles Lan card press pwr button for 30 second chk with adapter to boot
if no image keep attach adapter and press pwr button to turn off and pres pwr button again to boot
power chocking also causes to no imageLast edited by qayyum786; 04-27-2024, 10:58 AM.Comment
that's what I did, but same result, I was lucky today to have another identical model laptop with HS processor, so I recovered the 3 eeproms but I didn't display, I no longer have the LEDs flashing but the shift key still does not respond, I suppose the bios of the other laptop were good so the problem does not come from there, so I swapped the two micro controller (KBC34 and STM32), but the result is still the same, yet I have all the voltages, I guess the processor or the graphics card must have a problem thenComment
Can you share those 3 eeproms ,they might help someone else https://www.badcaps.net/forum/troubl...15#post3217015
Did you clean the ME firmware before trying the biosComment
Yes I share the 3 original bios files, can you clean the Intel region for me so I can do one last try please
Did you clean the ME firmware before trying the biosAttached FilesComment
clean meAttached FilesComment
Hi friends
please i need Dell g5 15 5500 bios
MB:SELEK MLK N18E
19753-1
old bios sometimes work
service tag: 70R4563
please clean bios
i7 10th generation1 PhotoComment
Dell G5 15 5500
Thẻ dịch vụ: 70R4563
Attached Files↵
https://www.badcaps.net/donateComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
