Dell G5 15 5500 bios needed
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: Dell G5 15 5500 bios needed
my laptop boots after finding correct bios but there is no service tag and no tpm module detected . tried inputting service tag in bios but it wont save it. my service tag is 8CK8S93. Can some one pleae help me ? ive included the bios files im using nowAttached FilesComment
Attached bios is your original one, or it's some dump you've tried? If not, upload your original dump even if it's corrupted.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
the person who did this is very disorganized and hes not sure if these are the right ones .... he has no others
Re: Dell G5 15 5500 Bios bricked after update
Sorry for bumping this up bit still i havent found a working bios for my laptop... Any help?Comment
Dell G5 5500 bios need to fix
I have attached the BIOS I extracted from both chips.
it give me one beep and no display
I would appreciate if someone fixed it for me.
service tag 367RF63Attached FilesComment
Re: Dell G5 5500 bios need to fix
Dell G5 15 5500
Service Tag: 367RF63Attached Files↵
​https://www.badcaps.net/donateComment
i need clean me
PCB_SELEK_G3_MLK_N18P_1979Attached FilesComment
You MUST NOT:- Post "clean me", "clear bios", "clean bios", "bios need", "clear me" or other such terms
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
.Last edited by SMDFlea; 09-24-2023, 03:35 AM.Comment
Try that on first boot put your service tag. tested 100% ok
give feedbackComment
Help, lost the dump. Service Tag 2T4VZZ2, need help on bios, all of the above not working, processor I7 10875h video card 2060. Platform selek mlk n18e 19753-1 fjt96$laComment
TRY.... flash both
give feedback please..Attached FilesComment
I have a problem with Dell G5 15 5500 i7-10750h 1660 Ti, the Bios has been damaged. In the BIOS, the Service Tag has been damaged, it has ??? in the name. ST: CDCS663Attached FilesLast edited by konradx; 12-14-2023, 08:33 AM.Comment
try a new build bios as per your Service Tag CDCS663 tag and as per your bios version 1.23.0
add service tag manually from maintenance tabLast edited by qayyum786; 12-19-2023, 08:02 PM.Comment
Unfortunately it doesn't work properly. After programming, the FAN starts at 100% power and restarts. A few restarts and the DELL logo appears and keeps restarting. Then, after a few shutdowns, the diagnostic display appears. I have been waiting for a long time, but the Dell logo is no longer displayed.​Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
- Loading...
