Asus K53SD v. 5.1 bios
  • Mcfalsi
    • Apr 2015
    • 191
    • Türkey
    Hİ K53SD REV5.1 BİOS DUMP VERSİON 208 Need please help
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: K53sd rev5.1 bİos
    can you upload your original dump
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • ManuCE
      • Sep 2021
      • 13
      • Italy
      Good evening. I own an asus k53sd with mb version 5.1. The laptop turns on but does not show anything on the screen. voltages are ok. I dumped the bios with a CH341a and the file is 65kb big. The original Asus bios file is too big to load. I understand that I need to extract only a part of the original file, but I can't figure out which one. Can anyone help me ? Thanks
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Re: Asus K53SD v. 5.1 bios
        Here you go:
        • ManuCE
          • Sep 2021
          • 13
          • Italy
          Originally posted by FrozenHaxor
          Here you go:
          Thank you very much. Can you help me ? Which part of the "Intel image" should I upload to the Mb ?
          The complete file is too big !
          Can you tell me how to do it?
            • 20898
            Use NeoProgrammer or AsProgrammer software, desolder the chip if you can and attach to an adapter board, or you might have problems if you`re using a clip .Choose the chip manually by the part number on top of it .
            Make 2 backups first, compare the files with HxD hex editor,look at both just make sure there`s some code in them.The backups should be 8MB not 65kb. Post your backup here before flashing any other bios
            https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
            https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
            HxD https://mh-nexus.de/en/hxd/
              • 20898
              Post a picture of the green/white barcode sticker on the ram slot as well .
              • ManuCE
                • Sep 2021
                • 13
                • Italy
                Here...thank you for the help.
                  • 20898
                  The chip you selected is only 512kb .Find the bios chip,then don`t auto-detect select it manually,look at the part number on top of the chip. Make 2 backups,don`t flash anything yet
                  • ManuCE
                    • Sep 2021
                    • 13
                    • Italy
                    The bios chip is an MXIC 25L512E. The data sheet lists it as 512Kb. I attach pictures. Thanks
                    • ManuCE
                      • Sep 2021
                      • 13
                      • Italy
                      This is the dump of my bios. I don't know if I did it right!
                      I've already flashed...
                        • 20898
                        Wrong chip,what you`ve posted is the USB3 firmware for the ASMedia IC .
                        The bios chip is 4MB not 8 as i said at post #4 ,
                        it should say something similar to 25Q32 on top
                        • ManuCE
                          • Sep 2021
                          • 13
                          • Italy
                          The bios chip is next to the big square chip with 128 legs. The bios chip is 4MB not 8 as i said at post #4 ,
                          Could it be this one ?
                            • 20898
                            yes
                            • FrozenHaxor
                              • Jun 2015
                              • 260
                              • Poland
                              That's not right, this dump is ready to use. You must be doing something wrong or the flash is broken.
                              • ManuCE
                                • Sep 2021
                                • 13
                                • Italy
                                yes
                                Good morning. I tried to load the bios "dump_work_rev5.1" but the pc doesn't boot. It turns on but doesn't show anything on the screen. I attach the original bios. Thanks
                                • ManuCE
                                  • Sep 2021
                                  • 13
                                  • Italy
                                  Thank you all. I solved it. Everything works. Without the ram the bios would not start !!! THANKS THANKS
                                  • FrozenHaxor
                                    • Jun 2015
                                    • 260
                                    • Poland
                                    Glad you got it working.
                                    • samirinfo
                                      • Mar 2020
                                      • 51
                                      • oran
                                      EC ROM ASUS k53sd rev 5.1
                                      help me EC ROM ASUS k53sd rev 5.1 ITE8572e dump
                                      Last edited by SMDFlea; 01-08-2022, 04:43 PM. Reason: Renamed crap thread title from "Need .help"
                                      • aboumohamed
                                        • Dec 2018
                                        • 258
                                        • algeria
                                        Re: Need .help
                                        try this dumps
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
