Asus K53SD v. 5.1 bios
  • samirinfo
    • Mar 2020
    • 54
    • oran
    Re: EC ROM ASUS k53sd rev 5.1
    thank you aboumohamed. but i need dump ec it8572e
    • Verlengsnoer
      • Sep 2016
      • 110
      • Netherlands
      will check for u, i have 7 k53 series laptop, if i have the k53sd then i will create a backup
      edit: found it and take a backup, hope it will work for you
      • samirinfo
        • Mar 2020
        • 54
        • oran
        THANK YOU SIR.VERLENGSNOER.YOUR BACKUP NOT WORK FOR ME.BECAUSE FILS IT8572E IS=128Ko
        • samirinfo
          • Mar 2020
          • 54
          • oran
          this my backup - rom ec it8572e but d'ont know if work or not
          • peste
            • 13449
            • ROMANIA
            post pictures with stickers in the ram memory area
            • Repdata
              • May 2020
              • 67
              • Deutschland
              #26
              test
              • abbassink
                • Aug 2015
                • 83
                • iran
                #27
                Originally posted by Repdata
                test
                it;s ok thankssssss
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
