Hİ K53SD REV5.1 BİOS DUMP VERSİON 208 Need please help
Asus K53SD v. 5.1 bios
Good evening. I own an asus k53sd with mb version 5.1. The laptop turns on but does not show anything on the screen. voltages are ok. I dumped the bios with a CH341a and the file is 65kb big. The original Asus bios file is too big to load. I understand that I need to extract only a part of the original file, but I can't figure out which one. Can anyone help me ? ThanksComment
Re: Asus K53SD v. 5.1 bios
Make 2 backups first, compare the files with HxD hex editor,look at both just make sure there`s some code in them.The backups should be 8MB not 65kb. Post your backup here before flashing any other bios
https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
HxD https://mh-nexus.de/en/hxd/Last edited by SMDFlea; 09-14-2021, 02:43 AM.Comment
Post a picture of the green/white barcode sticker on the ram slot as well .Comment
This is the dump of my bios. I don't know if I did it right!
I've already flashed...Attached FilesLast edited by ManuCE; 09-14-2021, 04:02 AM.Comment
The bios chip is 4MB not 8 as i said at post #4 ,
it should say something similar to 25Q32 on topLast edited by SMDFlea; 09-14-2021, 05:03 AM.Comment
That's not right, this dump is ready to use. You must be doing something wrong or the flash is broken.Comment
Good morning. I tried to load the bios "dump_work_rev5.1" but the pc doesn't boot. It turns on but doesn't show anything on the screen. I attach the original bios. ThanksAttached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by lrouw84Hi there,
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
