Lenovo V330 INVALID SN AND UUİD NUMBER
  • tipoti
    • Oct 2015
    • 34
    • turkey
    hi,
    i have lenovo v330, i tried many bios
    device turns on but does not turn on when legacy
    Is this problem because they don't have serial number and uuid numbers?
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1226
    • France
    Re: Lenovo V330 INVALID SN AND UUİD NUMBER
    Originally posted by tipoti
    hi,
    post the original dump and the one currently in use
    • tipoti
      • Oct 2015
      • 34
      • turkey
      ( v330 yedek ) orijinal files
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        DMI Info 0x201000
        • tipoti
          • Oct 2015
          • 34
          • turkey
          i don't understand what should i do now
          I guess the device doesn't boot in legacy mode because I didn't enter invalid ones
          which program should i use
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Become a Badcaps supporter
            Thanks to all supporters.
            • tipoti
              • Oct 2015
              • 34
              • turkey
              What should I do
              • tipoti
                • Oct 2015
                • 34
                • turkey
                can you help me
                • reformatt
                  • Feb 2020
                  • 1412
                  Refer to SMDflea's post for how to do this.
                  https://www.badcaps.net/forum/showthread.php?t=98038
                  I did this today on a 17807-3M motherboard (V330-15IKB) that I had to recover. The owner had switched the machine off during a BIOS update, thinking it was a virus. So putting this here to save someone else time in future. I did this on the donor dump after I had cleaned the ME.
                  Serial number etc is from 00201000 to 002011F0. So open your original dump and the donor BIOS in HxD. Highlight this block, copy, then paste it to the same location in the donor dump.
                  For the Windows product key, this is the same as the above post. Search for this Hex string and you'll find the key.
                  01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
                  Copy the 27D5D0 to 27D5FF block and paste this to the same location in the donor BIOS. Then write this back to the board and you should be sweet. A dirty ME will result in a pretty long wait on boot, so make sure you have a clean ME.
                  • NoFire
                    • Dec 2021
                    • 3
                    • Czech Rep.
                    Lenovo V330 15IKB - after update BIOS won't find a disc in the M.2 slot
                    Hi, can you please help me?
                    On Lenovo V330 15IKB - 81AX after replacing the chip on the board and the UPDATE BIOS is on the screen these data. BIOS won't find a disc in the M.2 slot Everything else works properly. Is it possible to fix it?
                    Thanks for the help
                    Images are in the appendix
                    (the disc in the image BIOS is the second SATA disk).
                      • 20933
                      Re: Lenovo V330 15IKB - after update BIOS won't find a disc in the M.2 slot
                      What did you replace the chip for ,do you have the original bios backup .
                      • NoFire
                        • Dec 2021
                        • 3
                        • Czech Rep.
                        I didn't repair the repair. I don't have a backup of BIOS.
                        • claudiuccg
                          • Apr 2021
                          • 11
                          • Romania
                          you have administrator password
                          • Yacine007
                            Lenovo ideapad 3 14IIL05 invalid serial number and system model
                            by Yacine007
                            Hello everyone i have lenovo ideapad 3 14IIL05 BIOS showing invalid product name and MTM and SN.
                            can someone help me with clean bios right informations.
                            Product name : ideapad 3 14IIL05
                            Model name : 81WD
                            SN : PF2FFSMM
                            MTM : 8IWD00QBSP
                            MFG DATE : 2020/12/26
                            FACTORY ID : JVHFC1
                            Thank you in advance...
                            11-25-2024, 04:33 PM
                          • AWFRONT
                            [Help Please!] Lenovo ThinkBook Plus Gen4 Twist-Help Needed with Restoring Serial Number and Product ID
                            by AWFRONT
                            I have recently purchased a Lenovo ThinkBook Plus Gen4 Twist with Dual Screen. Here are the links for the product information:
                            ThinkBook Plus Gen 4 (13″ Intel) | 13.3″ & 12″ Dual-Screen 2-in-1 Business Laptop | Lenovo UK
                            However, somehow the serial number and the product name is no longer showing under the BIOS, Windows 11 or Lenovo Vantage.
                            Strangely the laptop's under cover does not show any information about the Make, Model, Type or Serial Number (No sign of tampering but no labels etc...). I am not sure what to do.
                            I do not have access to the original box...
                            06-21-2025, 11:09 AM
                          • TecnicaNTT
                            Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                            by TecnicaNTT
                            I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                            My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                            I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                            I am now asking here for help if anyone knows how to do this in...
                            09-20-2024, 08:10 AM
                          • sikocan
                            Lenovo X1 Carbon 9th Gen Black Screen
                            by sikocan
                            I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                            SN: PF3G1REP
                            MODEL: 20KW-00J1AU
                            PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                            Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                            06-24-2025, 09:01 PM
                            Lenovo V V330 Notebook Specification for Upgrade or Repair
                            This specification for the Lenovo V V330 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the V330 boardview and V330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo V V330 Notebook...
                            09-06-2024, 12:51 PM
