Dell 7300 locked bios
  • vuquanghoanh
    • Feb 2023
    • 45
    • US
    #101
    Originally posted by minhdigital
    Send to you
    Working well. Thank so much
    Cảm ơn anh
    • balanel
      • Nov 2021
      • 4
      • Romania
      #102
      Pls help to unlock Dell 7300
      STAG:61NPM53
      EDC30 LA-G861P
      REV:1.0(A00)
      2019-02-23
      Thanks.​
      • rex98
        • Feb 2023
        • 1297
        • Mandaue CEBU, Philippines
        #103
        STAG:61NPM53
        EDC30 LA-G861P
        REV:1.0(A00)
        2019-02-23
        Thanks.​
        1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
        • balanel
          • Nov 2021
          • 4
          • Romania
          #104
          hello, is not starting with this dump.
          • rex98
            • Feb 2023
            • 1297
            #105
            oh i'm sorry i uploaded incorrect file. here is the correct one.
            • vvulture
              • Apr 2015
              • 17
              Originally posted by sebastiannielsen
              Now to the results.
              flashed in the file and verified the flash went good. worked perfectly, went into FACTORY MODE.
              but now to the odd thing:
              While in factory mode, and entering the service tag, the computer dies randomly before I got to save the service tag, it just rebooted in the middle of entering it.
              Tried again, went into factory mode, started entering service tag but it then died randomly again. (both times on DC power).
              Now it just turns on, fans on full speed, caps lock LED on.
              no beeps.
              Display test (D key) works.
              Tried reflashing the file again (I could see that the file does not match anymore, so the computer writes something to the BIOS).
              Same result.
              Verifying the BIOS chip shows that the content is again changed, so apparently it can boot the bootloader for the BIOS chip.
              I guess there is some hardware fault on the computer, so any ideas what it could be?
              Here is how the computer behaves:
              On DC only: Computer reboots every like 30 seconds, fans full speed, caps lock LED on, screen black.
              On battery only: Computer is stable, but screen is black all the time. Have had it on for like 15 minutes.
              On DC + Battery - same as Battery only.
              Tried both with BIOS battery attached and detached.
              Any ideas what could be the problem?
              Hey there.
              Just wondering if you got it all sorted out ? I'm having a similar issue..
              How did you go programming the 25B256 with the CH341a programmer ( i believe it was showing as a 25Q256 ) ? and did you program it on or off the board ?
              Thx
              • mayatech
                • Sep 2024
                • 8
                • usa
                #107
                can you unlock this file plz
                service tag 99VYY2
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12429
                  #108
                  Yes, but you must add service tag to your post, this is forum rule.
                  • mayatech
                    • Sep 2024
                    • 8
                    • usa
                    #109
                    sorry service tag
                    D99VYY2​
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12429
                      #110
                      sorry service tag
                      D99VYY2​
                      Files corrupted or wrong chip . Your bios file is 32MB , look for the chip with number 256 , for example 25Q256JV...
                      • mayatech
                        • Sep 2024
                        • 8
                        • usa
                        #111
                        this is the chip?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12429
                          #112
                          this is the chip?
                          No, this chip only holds 1MB of data. Read the post above.
                          • ragoub44
                            • Feb 2022
                            • 6
                            • morocco
                            #113
                            Dell latitude 7300
                            can someone pls unlock this bios for mE
                            service tag 40MJP13​
                            • rex98
                              • Feb 2023
                              • 1297
                              #114
                              Originally posted by ragoub44
                              Dell latitude 7300
                              upload the 16mb.
                              • shiyab
                                • Sep 2023
                                • 1687
                                • india
                                #115
                                Dell latitude 7300
                                UNLOCK TRY
                                • Khaled Mohamed
                                  • May 2024
                                  • 5
                                  • egypt
                                  #116
                                  Originally posted by Markus1741
                                  Try and let me know how it works ....
                                  Dont work make laptop flash orange no up​
                                  bump. Any help please
                                  • rex98
                                    • Feb 2023
                                    • 1297
                                    #117
                                    no one will help you won't upload the 16mb bios.
                                    • Marcel Markefka
                                      MARSSS
                                      • Dec 2024
                                      • 3
                                      • Poland
                                      #118
                                      Witam,
                                      czy ktoś z Was może mi pomóc odblokować BIOS w moim Latitude 7300?
                                      service tag : JVSZP13
                                      Z góry dziękuję
                                      • LBTT1121
                                        • Nov 2024
                                        • 1227
                                        • Việt Nam
                                        #119
                                        Originally posted by Marcel Markefka
                                        Witam,
                                        Z góry dziękuję
                                        try
                                        • Marcel Markefka
                                          MARSSS
                                          • Dec 2024
                                          • 3
                                          • Poland
                                          #120
                                          Originally posted by LBTT1121
                                          try
                                          I wasn't sure if changing code in two places was necessary, but it works very well, thank you
                                          and sorry for the previous post, I wanted to write it in English but I didn't notice that Google Translator automatically changed my entry to Polish
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
