One question: the new bios, obviously, has an empty serial number. Is there any issue with leaving it blank, or should I re-enter it manually? Just wondering if the sn is picked up during software updates or similar scenarios and not having it could cause problems. I left it blank for now.
HP ZBOOK 14U G6 Bios Password
there is no issue if you want to use it as it isOne question: the new bios, obviously, has an empty serial number. Is there any issue with leaving it blank, or should I re-enter it manually? Just wondering if the sn is picked up during software updates or similar scenarios and not having it could cause problems. I left it blank for now.
just skip DMI ERROR on startup or you can fill DMI DATA by the help of Use this HP BCU TOOL Comment
I did unsolder the 32mb bios chip from the board and did read it via ch341a with small wires,
here is my backup .bin
can you please help me unlock the password and if there is computrace disable that?
thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
Can someone help me clear the password and computrace?
serial number
5CG9356X9W
Thank you this is the 32mb chipAttached Filesif you find these attachements useful please consider making a small donation to the site
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU
here's u'r DMI:
Serial Number: 5CG9356X9W
Product #/SKU: 7ZC43UT#ABA
CT Number: PHWHV00WBCP10Q
Description: HP ZBook 14u G6
BuildID: 19WWCFAT603#SABA#DABA
Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBapaqauawb8bUbhcAdUdpdqfAfPhKhkj4jhk8.RHAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank you,
here's u'r DMI:
i did flash and resolder bacm to the board now the caps lock light stuck on and no powerComment
Please help
I did brick the laptop it only had bios password but it was bootable with usb flash and to windows
Now i flashed the patched backup bios and the caps lock stays on
I tried to flash my backup and still same.
I tried flashing other backups from the forum still not working only caps lock is on
Please helpComment
check solder, flash back your original dump. if it doesn't work upload here the EC.Please help
Please helpComment
hello yes i did resolder and checked all the solders they are ok, i did flash someone elses dump and now the caps lock like flashing, also very milisecond the power light also flashes very light flash when the power cord is plugged in,
i am uploading my original dumps here again the 16mb and 32mb
I did try to put back my original dump it did not work
please helpAttached Filesif you find these attachements useful please consider making a small donation to the site
flash both. be patient in first boot it would take long.hello yes i did resolder and checked all the solders they are ok, i did flash someone elses dump and now the caps lock like flashing, also very milisecond the power light also flashes very light flash when the power cord is plugged in,
check the solders if they were done well...Comment
Hello! Good day. Could anyone please assist me with removing the BIOS administrator password on an HP ZBook 14u G6? I would be very grateful for any help. Thank you!Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
Channel: BIOS Requests ONLY!
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by zlr8rGreetings
I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
Serial Number: 5CG3202C16
Product #/SKU: 739P0AV
CT Number: PRTUE00WBI30YX
Description: HP ZBook Firefly 14 inch G10
BuildID: 23WWWGAZ602#SABU#DABU
Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
MAC address not found.- I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
- Loading...
