HP ZBOOK 14U G6 Bios Password
  • Jedeone
    • Apr 2024
    • 7
    • Scotland
    #41
    One question: the new bios, obviously, has an empty serial number. Is there any issue with leaving it blank, or should I re-enter it manually? Just wondering if the sn is picked up during software updates or similar scenarios and not having it could cause problems. I left it blank for now.
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      #42
      there is no issue if you want to use it as it is
      just skip DMI ERROR on startup or you can fill DMI DATA by the help of Use this HP BCU TOOL
      • Jedeone
        • Apr 2024
        • 7
        • Scotland
        #43
        thank you sir👍
        • evoospeed
          • Sep 2017
          • 9
          • Armenia
          #44
          hello i have the same laptop it has bios password but it can boot to windows or usb flash drive, is there any other way to unlock ? if not which IC i need to read? and do i have to do it with ch341a ? please help and thank you.
          • evoospeed
            • Sep 2017
            • 9
            • Armenia
            #45
            I did unsolder the 32mb bios chip from the board and did read it via ch341a with small wires,
            here is my backup .bin
            can you please help me unlock the password and if there is computrace disable that?
            thank you.
          • evoospeed
            • Sep 2017
            • 9
            • Armenia
            #46
            thank you.
            I am sorry,
            Serial Number 5CG9356X9W
            • evoospeed
              • Sep 2017
              • 9
              • Armenia
              #47
              Can someone help me clear the password and computrace?
              serial number
              5CG9356X9W
              Thank you this is the 32mb chip
              • rex98
                • Feb 2023
                • 1235
                • Mandaue CEBU, Philippines
                #48
                serial number
                5CG9356X9W
                first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                use BCU. you can permanently disable Absolute lock in BCU
                here's u'r DMI:
                Serial Number: 5CG9356X9W
                Product #/SKU: 7ZC43UT#ABA
                CT Number: PHWHV00WBCP10Q
                Description: HP ZBook 14u G6
                BuildID: 19WWCFAT603#SABA#DABA
                Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBapaqauawb8bUbhcAdUdpdqfAfPhKhkj4jhk8.RH​
                • evoospeed
                  • Sep 2017
                  • 9
                  • Armenia
                  #49
                  here's u'r DMI:
                  Thank you,
                  i did flash and resolder bacm to the board now the caps lock light stuck on and no power
                  • evoospeed
                    • Sep 2017
                    • 9
                    • Armenia
                    #50
                    Please help
                    I did brick the laptop it only had bios password but it was bootable with usb flash and to windows
                    Now i flashed the patched backup bios and the caps lock stays on
                    I tried to flash my backup and still same.
                    I tried flashing other backups from the forum still not working only caps lock is on
                    Please help
                    • rex98
                      • Feb 2023
                      • 1235
                      #51
                      Please help
                      Please help
                      check solder, flash back your original dump. if it doesn't work upload here the EC.
                      • evoospeed
                        • Sep 2017
                        • 9
                        • Armenia
                        #52
                        hello yes i did resolder and checked all the solders they are ok, i did flash someone elses dump and now the caps lock like flashing, also very milisecond the power light also flashes very light flash when the power cord is plugged in,
                        i am uploading my original dumps here again the 16mb and 32mb
                        I did try to put back my original dump it did not work
                        please help
                        • rex98
                          • Feb 2023
                          • 1235
                          #53
                          please help
                          flash both. be patient in first boot it would take long.
                          • evoospeed
                            • Sep 2017
                            • 9
                            • Armenia
                            #54
                            Any flashing tips?
                            i have ch341a black edition using neoprogeammer
                            any tips for flashing ?
                            • evoospeed
                              • Sep 2017
                              • 9
                              • Armenia
                              #55
                              So redid flash both chips
                              https://photos.app.goo.gl/UVyMgCcLYXYnLAHN9
                              same situation.
                              • danito
                                • Jun 2016
                                • 842
                                • Romania
                                #56
                                same situation.
                                check the solders if they were done well...
                                • rex98
                                  • Feb 2023
                                  • 1235
                                  #57
                                  that bios i posted is working and tested by me. so it should work.
                                  • Slava24
                                    • Oct 2024
                                    • Ukraine
                                    #58
                                    Hello! Good day. Could anyone please assist me with removing the BIOS administrator password on an HP ZBook 14u G6? I would be very grateful for any help. Thank you!
                                    • peste
                                      • Dec 2016
                                      • 12246
                                      • ROMANIA
                                      #59
                                      post the S/N, the motherboard model, etc.
                                      • Slava24
                                        • Oct 2024
                                        • Ukraine
                                        #60
                                        Hello. I was able to resolve the issue on my own. I appreciate your willingness to help!
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • snpetit
                                          Asus FA706IH Bios Password remove
                                          by snpetit
                                          i need some help :-/
                                          i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                          Could you please remove all password related stuff from this bios. A hate Asus....
                                          Thanks in advance!...
                                          01-10-2025, 09:17 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
                                        • beBoss
                                          HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                          by beBoss
                                          as noobie to this please excuse my lack of experience.
                                          I am trying to remove a BIOS password from this machine:
                                          HP ProDesk 400 G6 Mini
                                          but so far I still have no success.
                                          I bought CH341 programmer and decided to give it a try.
                                          The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                          I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                          05-30-2024, 12:48 PM
