Panasonic CF53 MK4 CF-532S74RMG
  • peste
    • Dec 2016
    • 12748
    • ROMANIA
    #81
    Re: Panasonic CF53 MK4 CF-532S74RMG
    Originally posted by Lucke
    Hi guys, I have a CF-53 mk4 identical to that of ponchik123 (post 77), with PW. Can I use the mod released by peste also for mine?
    no ... try this ...
    • Lucke
      • Apr 2022
      • Italy
      #82
      Thanx peste
      • spidero77
        • Jan 2023
        • 5
        i have a toughbook CF-53 mk4
        Windows is booting from an USB-Stick, but it is bios locked
        Serial: - CF-532nxbymg
        Aptio 4 Ami delivers me a 6 MB file
        can someone unlock it?
        I try to upload it with Aptio4Ami, is that working?
        or what is the solution without opening the laptop-case
        bye
        • WhateverGDR
          • Nov 2021
          • 22
          • Whereever
          #84
          Try the Attachment and report.
          • telpurleith
            • Aug 2023
            • 4
            Hello Guys, could you help me please? I have a CF-53 MK4 with an pw.
            • WhateverGDR
              • Nov 2021
              • 22
              • Whereever
              #86
              Try the attached file...
              • telpurleith
                • Aug 2023
                • 4
                thx mate that worked without any problems so far. have a nice weekend. you have saved me so much
                • Lucastester
                  • Aug 2023
                  • 9
                  Hi guys I have a Bios locked Panasonic CF-53 MK4
                  Model:CF-532SLZACM
                  S/N: 6CTSA56886
                  Need Mac Adress to match pleas and ME Firmware to match
                  If you guys can make it boot with the "Panasonic" logo that would be great too thank you!
                  Last edited by Lucastester; 01-30-2024, 02:44 PM. Reason: Forgot to ask for ME clear
                  • peste
                    • Dec 2016
                    • 12748
                    • ROMANIA
                    #89
                    Model:CF-532SLZACM
                    S/N: 6CTSA56886
                    try..
                    • Max Vavilov
                      • by
                      #90
                      cf-532s74rmg
                      s/n:5ktca37214​
                      • peste
                        • Dec 2016
                        • 12748
                        • ROMANIA
                        #91
                        cf-532s74rmg
                        s/n:5ktca37214​
                        both bios are corrupted ..remove the bios chip from the motherboard before reading or writing, or stick wires between the chip and the peogrammer..post again..
                        • markv81
                          Markv
                          • 18
                          • Netherlands
                          #92
                          try it with a 64 bit windows OS, w10 (64 bits), it solved mine problems working on a cf-19 mk4. Use CH341A Mini Programmer V1.29 with the 64 bit drivers. And be sure the clam on the chip is fitting WELL.
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • James Jackson
                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                            by James Jackson
                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                            05-01-2025, 11:28 AM
