Panasonic CF53 MK4 CF-532S74RMG
  • peste
    • 13630
    • ROMANIA
    #81
    Re: Panasonic CF53 MK4 CF-532S74RMG
    Originally posted by Lucke
    Hi guys, I have a CF-53 mk4 identical to that of ponchik123 (post 77), with PW. Can I use the mod released by peste also for mine?
    no ... try this ...
    • Lucke
      • Apr 2022
      • Italy
      #82
      Thanx peste
      • spidero77
        • Jan 2023
        • 5
        i have a toughbook CF-53 mk4
        Windows is booting from an USB-Stick, but it is bios locked
        Serial: - CF-532nxbymg
        Aptio 4 Ami delivers me a 6 MB file
        can someone unlock it?
        I try to upload it with Aptio4Ami, is that working?
        or what is the solution without opening the laptop-case
        bye
        • WhateverGDR
          • Nov 2021
          • 22
          • Whereever
          #84
          Try the Attachment and report.
          • telpurleith
            • Aug 2023
            Hello Guys, could you help me please? I have a CF-53 MK4 with an pw.
            • WhateverGDR
              • Nov 2021
              • 22
              • Whereever
              #86
              Try the attached file...
              • telpurleith
                • Aug 2023
                thx mate that worked without any problems so far. have a nice weekend. you have saved me so much
                • Lucastester
                  • Aug 2023
                  • 9
                  Hi guys I have a Bios locked Panasonic CF-53 MK4
                  Model:CF-532SLZACM
                  S/N: 6CTSA56886
                  Need Mac Adress to match pleas and ME Firmware to match
                  If you guys can make it boot with the "Panasonic" logo that would be great too thank you!
                  Last edited by Lucastester; 01-30-2024, 02:44 PM. Reason: Forgot to ask for ME clear
                  • peste
                    • 13630
                    • ROMANIA
                    #89
                    Model:CF-532SLZACM
                    S/N: 6CTSA56886
                    try..
                    • Max Vavilov
                      • by
                      #90
                      cf-532s74rmg
                      s/n:5ktca37214​
                      • peste
                        • 13630
                        • ROMANIA
                        #91
                        cf-532s74rmg
                        s/n:5ktca37214​
                        both bios are corrupted ..remove the bios chip from the motherboard before reading or writing, or stick wires between the chip and the peogrammer..post again..
                        • markv81
                          Markv
                          • 18
                          • Netherlands
                          #92
                          try it with a 64 bit windows OS, w10 (64 bits), it solved mine problems working on a cf-19 mk4. Use CH341A Mini Programmer V1.29 with the 64 bit drivers. And be sure the clam on the chip is fitting WELL.
                          • mazharhussain
                            • Jul 2025
                            • 8
                            • UNITED KINGDOM
                            #93
                            HI Team,
                            Please help me unlock the panasonic cf-52 i5 vpro
                            below is the details of the laptop
                            Model no: CF-52VACBYDE
                            Serial no: 4LTCA86903
                            Thanks in advance.
                            • peste
                              • 13630
                              • ROMANIA
                              #94
                              Originally posted by mazharhussain
                              HI Team,
                              Thanks in advance.
                              try..
                              • AquaMan Ua
                                Problem with PANASONIC CF53 laptop after changing BIOS settings
                                by AquaMan Ua
                                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                05-17-2025, 09:40 AM
                              • aa10aa10
                                Panasonic Toughbook CF-33 mk1 BIOS repair
                                by aa10aa10
                                Good day,
                                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                01-21-2025, 06:13 AM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
