Dell Latitude 5400 Bios password
Hello I already patch my bios I have Dell Latitude 5400 8fc8 the admin password has been removed but I couldn't install Operating System it either goes bluescreen or no bootable device. The usb bootable drive is detected and I can install the OS but after restart it goes BSODComment
Hello guys. I bought a Latitude 5400 from a site. I turn it on and it says "this computer is protected by a password authentication system".
Can you help me remove this password? Besides the model number, S/T, board model, which of the two flash chips should i remove and read to post here the content? There are 2 bios chips on the board. Thank you!Comment
DELL LATITUD 5400
MODEL LA G891P
SERVICE TAG C8SD433
PROBLEM BIOS PASSWORD
THANKSSAttached Filesif you find these attachements useful please consider making a small donation to the site
3.4. Dell
Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
Note: There is no publicly available 8FC8 generator available at the moment.
The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcherβ΅
βhttps://www.badcaps.net/donateComment
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
At first boot press F2, write your Service Tag, disable Absolute if it was activated, Save and Exit.Attached Filesif you find these attachements useful please consider making a small donation to the site
Didn't work out
3.4. Dell
ThanksComment
Actually its does works
3.4. Dell
With dell patcher but i had to wipe the chip first
Thank you so much
And thanks for everybody for helping me
I tried to remove the BIOS password on my Dell Latitude 5400 using the patcher.
Got a the bios dump with the programmer
And unlocked it with the patcher
But now whether I upload the initial dump or the unlocked dump, when I connect the power, the front led is white, the power button and the keyboard lights up for 1-2 seconds, the fan also starts for 1-2 seconds and it keeps repeating.
Please help.
Service Tag: J9XQ433
Board: LA-G891P
Thank you very much!Attached Filesif you find these attachements useful please consider making a small donation to the site
You copied the bios with errors.Hello,
Please help.
Board: LA-G891P
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
.here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I understand, but since I copied the original BIOS with errors, after I unsolder it, what BIOS I should write on it?
Can you help me with a suggestion?
Thank you!Comment
try and feedbackHello,
Please help.
Board: LA-G891P
I wrote the BIOS on the chip using the WSON8 probe, verified it twice but still the same behavior.
I don't have knowledge of soldering to try and unsolder it, but I suspect that I might have damaged the chip connections to the motherboard with the probe, hence I will try with a local service to have it checked.
I'm attaching two pics of the BIOS chip for your opinion.
Thank you very much for all the help.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello you can try this new build bios from your corrupt original bios good luck ....Hello,
Hello Everyone, I have 8 dell Latitude 5400 laptops, Example: SERVICE TAG(S/N): 9L7K5Y2
MFG YR:2019
20873528858
EXPRESS SERVICE CODE.
Beg Model/z: P98G
Reg Type No.. P98G001, the question is, can I find someone to help me privately to find out the bios password? including telling me which bios reader to buy, I am willing to contribute with a donation to the forum. Thanks, GeorgeComment
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, π π π ...-
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* βBIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...09-06-2024, 12:13 PM
- Loading...
