Dell Latitude 5400 Bios password
  • Markus1741
    • Sep 2020
    • 972
    • N/A
    #701
    Originally posted by moshu
    please help to remove pasword on below 5400.
    I've tryed
    1- Select the range 00045000 to 00048fff
    2- Select "Edit" then "Fill"
    3- Put "ΓΏ" in "Pattern" zone.
    4- Choose "Fill selection" then clic on "Fill" button.
    5- Save the new file."
    but laptop didnt start
    Model: Dell Latitude 5400
    Board: EDC41LA-G892P
    REV: 1.0 (A00)
    SERVICE TAG: 9QGW3Z2-8FC8
    read one CHIP GD25Q256DY1G
    Hello try this unlocked file ....
    • moshu
      • Oct 2024
      • 66
      • Ireand
      #702
      Thanks Marcus,
      I will really want to learn how you did that, because I still have 11 laptops to fix (same model), some with 2 bios chips some with one.
      Is there a tutorial for beginners somewhere to follow?
      Last night I've been able to fix other 2 laptops testing some of the bin files already shared on this thread, and found 2 files compatible (Latitude E5400_256_CLEAN.rar & BACKUP_DELL LATITUDE 5400 EDC41 LA-G891P REV 1.0(A00) 2019-03-28.rar)
      • hoaca388
        Badcaps
        • Jan 2022
        • 12423
        #703
        Thanks Marcus,
        https://www.badcaps.net/forum/troubl...s-out-for-free
        ​https://www.badcaps.net/donate
        • moshu
          • Oct 2024
          • 66
          • Ireand
          #704
          Great, in the case of laptops with 2 BIOS chip I suppose I will have to patch both, I suppose
          • moshu
            • Oct 2024
            • 66
            • Ireand
            #705
            I've try link above but doesn't want to generate the patch file for the 16M chip, it does for the 8M chip instead. Below is the error:
            Rex98 **Dell-8FC8-Patcher**
            @Tecshack Cebu
            Pag huwat ky ga patch pa!...in file W25Q128JV@SOIC8_61F0533_PSW_V2.BIN
            wa nakit-an ang intel signature
            Pinduta bisan unsang key para ma exit...​
            Please help me understand what I have to do next.
            In the meantime if someone can patch both file for me
            Board: EDC41LA-G891P
            REV: 1.0 (A00)
            SERVICE TAG: 61F05-8FC8
            • Markus1741
              • Sep 2020
              • 972
              • N/A
              #706
              @Tecshack Cebu
              REV: 1.0 (A00)
              Now you can see how well the Rex98 software works.
              The 16MB Bios chip doesn't need to be patched because nothing is found in it.
              If you have 2 chips, as in your case, you have to consider which of the two should be processed.
              In your case only the 8MB chip needs to be written back.​
              • moshu
                • Oct 2024
                • 66
                • Ireand
                #707
                thanks, I've used the patch for the 8MB chip and initially computer restarted every 5 seconds Redo the soldering and is good now
                Thanks again
                • moshu
                  • Oct 2024
                  • 66
                  • Ireand
                  #708
                  Thanks again
                  I've read the 8MB chip on the the 2nd Laptop , but Rex patcher doesnt recognize. I've read the 16MB as well, went through the patcher and the same.
                  Any idea what is wrong here?
                  • moshu
                    • Oct 2024
                    • 66
                    • Ireand
                    #709
                    in the end I've write the same patch from the first computer to the 2nd and is working
                    • moshu
                      • Oct 2024
                      • 66
                      • Ireand
                      #710
                      hi, is me again, last laptop is giving me headache. I am not able to READ or FLASH the 8MB chip, as the other ones. Is giving an error :
                      Pin detected passed
                      Check ID Error!
                      Checked ID is : 0x FF FF FF
                      Wish to continue programming, please cancel[Check Device ID] option!​
                      I did disable "Check ID" and reading went through, but writing Didn't.
                      Is there any solution for this issue?
                      Chip is the same as for the other ones so is not possible to pick a wrong chip from the list
                      Thanks in advance
                      • dhudz1968
                        • Feb 2018
                        • philippines
                        #711
                        please help need to unlock
                        service tag:BJWDL33
                        THANK YOU
                        • shiyab
                          • Sep 2023
                          • 1676
                          • india
                          #712
                          service tag:BJWDL33
                          THANK YOU
                          hi try
                          • selcuk
                            • Aug 2014
                            • 8
                            • turkey
                            #713
                            dell 5400 : S TAG : D0MXP13
                            ŞİFREYİ KALDIRMAMA YARDIMCI OLABİLİR MİSİNİZ?
                            • shiyab
                              • Sep 2023
                              • 1676
                              • india
                              #714
                              Originally posted by selcuk
                              CAN YOU HELP ME REMOVE THE PASSWORD?
                              post snid
                              • selcuk
                                • Aug 2014
                                • 8
                                • turkey
                                #715
                                dell latitue 5400
                                s tag : D0MXP13
                                D0MXP13-E7A8
                              • shiyab
                                • Sep 2023
                                • 1676
                                • india
                                #716
                                dell latitue 5400
                                s tag : D0MXP13
                                D0MXP13-E7A8
                                hi try and feedback
                                • selcuk
                                  • Aug 2014
                                  • 8
                                  • turkey
                                  #717
                                  shiyb
                                  thank you very much it works without any problems best regards
                                  • MattiaGrylls
                                    • Dec 2024
                                    • ITALY
                                    #718
                                    Hi everyone, i,ve bought 4 dell 5400, all with same bios password. how can i reset they? i've read some pages of these topic, how can i post bios dump? i'm not so much expert, sorry.
                                    please someone with patience can explane me step by step what i have to do? thanks a lot, have a happy new year. i'm italian
                                    • peste
                                      • 13827
                                      • ROMANIA
                                      #719
                                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                      • brokemch0rd
                                        • Jul 2024
                                        • US
                                        #720
                                        Hello, please help me to unlock my Dell latitude 5400
                                        EDC41 LA-G891P REV 1.0 (UC5)
                                        service tag: 8B41N13-8FC8
                                        Thanks!
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                          11-02-2024, 04:19 AM
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          11-08-2025, 10:04 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                          09-06-2024, 12:13 PM
