Dell Latitude 5400 Bios password
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    #221
    Re: Dell Latitude 5400 Bios password
    Originally posted by MBAS111
    is Serial OK: HGFB533
    Your backup fault.
    ​https://www.badcaps.net/donate
    • MBAS111
      • Oct 2022
      • 60
      #222
      Can i not find an original Bios?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12423
        #223
        You said your bios has a password which means bios file in your bios chip is fine, but the file you posted back is corrupt, so the problem is your programmer, which model programmer do you use?
        • MBAS111
          • Oct 2022
          • 60
          #224
          neo programmer. you may be right before i looked deeper into re programming chips i made a mistake and took a bois backup from a clip. I now solder directly onto the board to reprogram. so i don't have a valid bios back up does that mean this unit is scrapped
          • MBAS111
            • Oct 2022
            • 60
            #225
            can an original bios work?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12423
              #226
              Not sure.If your bios reading has failed, who can guarantee that the bios writing is successful? solve your bios reading problem or you will make things more difficult.
              • MBAS111
                • Oct 2022
                • 60
                #227
                problem is i have already overwitten before so that was the only backup i had
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12423
                  #228
                  Does your device include one or two bios chips?
                  • MBAS111
                    • Oct 2022
                    • 60
                    #229
                    just the one
                    • MBAS111
                      • Oct 2022
                      • 60
                      #230
                      So without a bios backup is it not possible to restore the chip info back to factory?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12423
                        #231
                        Try
                      • wafer
                        • Nov 2022
                        Hi, I am hoping someone can help me to disable Absolute in this bios backup.
                        I managed to permanently activate it due to the confusing wording in the bios GUI.
                        LA-G891P Tag HQ107Y2
                        • procyone
                          • Feb 2020
                          • 13
                          #233
                          Hi all.
                          Need password removal please.
                          • hardware1
                            • Sep 2021
                            • 2949
                            • N/A
                            #234
                            Originally posted by procyone
                            Hi all.
                            Here's your Unlocked file, try it and let me know.
                            all donations are welcome,
                            • procyone
                              • Feb 2020
                              • 13
                              #235
                              Only keyboard backlight and fan on full spin
                              • hardware1
                                • Sep 2021
                                • 2949
                                • N/A
                                #236
                                Did you solder the chip Correctly? try to use your backup and see what will happen.
                                • tayeb_ama
                                  Banned
                                  • Aug 2016
                                  • algeria
                                  #237
                                  hello bros. i have dell Latitude 5400 windows Mobile Device Management any solution this is my device bios dump thank you
                                  • tayeb_ama
                                    Banned
                                    • Aug 2016
                                    • algeria
                                    #238
                                    Problem solved thank you any ways
                                    • Japanac
                                      • Aug 2014
                                      • 95
                                      • Serbia
                                      #239
                                      Hi all.I don't know which chip contains the password, so I post the content from both.
                                      • volinakis
                                        • Jan 2021
                                        • 2875
                                        • N/A
                                        #240
                                        try
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                          11-02-2024, 04:19 AM
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          11-08-2025, 10:04 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                          09-06-2024, 12:13 PM
