  • razor_amd
    • Sep 2013
    • 74
    • Serbia
    This is the picture of 3 similar ASUS motherboards, all of them being X555LD but different versions:
    In next picture below, all of them have different BIOS versions. On ASUS motherboards, always look for this sticker, it will tell you the correct BIOS version and version which came with the board. (I am sorry if I didn't order pictures correctly, to mach boards with stickers, I am just writing to help you know what to look for when you get one for repair)
    First board has X555LA bios version 202, ASUS is naming it X555LAAS.202
    Second board has X555LB bios version 332, ASUS is naming it X555LBAS.332
    Third board has X555LJ bios version 360, ASUS is naming it X555LJAS.360
    Note that all BIOS files downloaded from ASUS website have "AS" suffix next to model name followed by the BIOS version. I will tell you later, one more info about that.
    I think this ASUS X555LD motherboard has the most BIOS versions. Couple more BIOS versions also applicable for this motherboard are: X555LAB, X555LN, X555LNB, X555LD, X555LDB.
    Next, now you know the correct version of the BIOS that goes into your motherboard, go to ASUS support website or search through Google if you don't see the specific model on ASUS website, and download BIOS for the notebook model written on the sticker. If it is written X555LA on the sticker than type X555LA and download BIOS that says X555LA.
    Next step is to read your original BIOS from the board and open it in HEX editor. I use WinHEX because it is easiest to work with. Go to Search -> Find Text or just press Ctrl+F on a keyboard and type in X555. Don't type anything else after X555, it's easier to find the correct version.
    I opened a random BIOS I have on my server so it will not mach the one written on a sticker here, but you get the point. When you read yours it should mach 100% if no one before you tampered with it or updated it.
    On the picture you can see there are couple of places where you can find out exactly what bios version it is. The address 0x230000 is where DMI data starts, and it ends with 0x27FFFF. If you want your serial number, model, windows key, you need to copy this information from old BIOS to the new one you will make later on...
    Next step is to check the Intel ME version used in original BIOS file. Use the ME Analyzer that plutomaniac made from Win-Raid forums and find out the version.
    We see here that we need Intel ME 9.5.15.1730 firmware with 1,5MB in size from Win-Raid repository and you will need Intel ME 9.5 System Tools also from Win-Raid forums. Unpack Flash Image tool and the correct clean ME firmware from the archives.
    Now, you will have to use this great guide, again from Win-Raid forums, that is being constantly updated with new stuff. Follow D3. ME 7 - 10 & TXE 1 - 2 paragraph with a little bit of changes which I will tell you now. Skip the preparation of ME region because we already did that. Go all the way to the step 7, here is where we make one change. Unpack and copy previously downloaded BIOS from ASUS website to the FITC folder and also copy clean ME region file. Open the extracted ASUS file in HEX Editor and delete first 2KB of it. Almost on all downloaded ASUS BIOS files you need to delete first 2KB. You can also compare the 2 files in HEX editor and make the downloaded file from ASUS start exactly like BIOS Region.bin file.
    Now you only have to remove original BIOS Region.bin file and ME Region.bin file from the folder and rename your files exactly like the ones you removed.
    X555LAAS.312 to BIOS Region.bin and
    9.5.15.1730_1.5MB_PRD_RGN.bin to ME Region.bin
    Continue with Step 8 and further and make your completely clean BIOS that will be in "Build" folder named outimage.bin. Step 11 and 12 are not needed. I never did any of that.
    I suggest you rename this outimage.bin file to X555LAAS.312.bin (the name you get when extracting bios from ASUS website with .bin extension added to the end) so you would know that this is the clean complete BIOS image for ASUS X555LD motherboard with bios X555LA version 312.
    You may now open old BIOS and newly made BIOS in HEX editor, it is easier to compare them and copy the DMI data from old bios file to new and always Save As new BIOS file so you will have your clean file untouched. Most ASUS notebooks work great without copying the DMI data, just program the correct made image without DMI data.
    For the "AS" suffix. There are engineering BIOS-es for ASUS notebooks. They are the files that only ASUS Engineers can download from their servers with specific hardware installed at ASUS service centre. Those files are already complete BIOS files with Clean ME and no DMI data already setup for every notebook that exists from ASUS. You will recognize these BIOS-es because insted of the "AS" suffix after the bios model, they have an "F1" suffix.
    X555LAAS.317 -> X555LAF1.317
    That is all from me. If I remember anything else, I will add to my post. Moderators can also move this tutorial to the second place if possible, for easier access.
    Thank you all for reading and happy modding.
    Last edited by SMDFlea; 05-05-2023, 01:42 PM. Reason: Edited winraid repository and system tools links
  • aldopc
    • Jul 2017
    • 465
    • Chilito
    Re: [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
    Thanks Excelent
    • 5chematic
      • Jun 2019
      • 77
      Hello razor,
      Thank you for sharing this great info about unlocking Asus laptops.
      I will share an experience I had with an Asus that I unlocked a few months ago.
      This was an Asus Q406D to be exact.
      And these were the steps that I had to follow:
      1.) I visited: asus.com/us/Laptops
      2.) Filled in the Asus laptop model, etc.
      3.) Downloaded the bios file in a zip format.
      4.) After unziping it I ended up with this file: Q406DAAS.304
      5.) Then here comes the tricky part.. honestly I have no idea how I did it...
      Using HxD I combined the original locked bios with this other file. I do not recommend to remane the .304 to .bin as the file will become corrupted. in the original locked file I removed must of his content and lefted intact the Q406DAAS.304 then saved the file. after I turned on the Asus it took a while for the system to update the changes. I did received many errors but after each errors the system restared the machine, but like I said it took a while but thats how I removed the bios password.
      Next time I come across another Asus I will use your method.
      • rediii
        h???, spurrrn
        • Mar 2018
        • 485
        • somewhere in europe
        well done
        • hoaca388
          Badcaps
          • Jan 2022
          • 11525
          • Viet Nam
          Thanks for your share. Razor AMD.
          • deditriadi
            • Jan 2022
            • Jambi
            Thank you Razor for sharing the goodness
            • fyaagoub
              • Dec 2016
              • 269
              • maroc
              thanks
              • lapfix
                • Mar 2020
                • 2696
                • my workshop
                Great tutu , thank you
                • lapfix
                  • Mar 2020
                  • 2696
                  • my workshop
                  Question : what to do in this case !
                  Asus X555LD rev 3.3 ...at the sticker we have X555LDB ( 332)...so 332 is the version which came with the board...go to asus site..choosing x555LDB and the last ver is 307..so how toproceed here !
                  • lotas
                    • Jan 2016
                    • 4535
                    • Russia
                    There are two versions LD and LDB.
                    • DF-TECH-HT
                      • Oct 2021
                      • 3
                      • France
                      • lapfix
                        • Mar 2020
                        • 2696
                        • my workshop
                        thank you
                        • musanide
                          JQUB
                          • May 2020
                          • 86
                          • zambia
                          beautifull
                          • unlu60
                            • Nov 2015
                            • TÜRKİYE
                            Originally posted by musanide
                            beautifull
                            Thanks Excellent
                            • goliat17120
                              • Nov 2022
                              • 4
                              • france
                              Un grand MERCI ! WHAOU !!! Mais quel bon travail !!! Excellent ������
                              A big THANK YOU! WHAOU!!! But what a great job!!! Excellent
                              • Kemer
                                • Apr 2023
                                • 37
                                • Turkey
                                I can not see any picture, sticker in above post. Do you? Where are they?
                                • Kemer
                                  • Apr 2023
                                  • 37
                                  • Turkey
                                  Originally posted by Vesko356
                                  All images are viewable without any issue, even through my phone's browser - I just checked to make sure everything is OK.
                                  Yes. Unfortunatly my false. I noticed after quote the original post. I could see postimage.com links and could open them only with a VPN.
                                  I couldn't see any pic or link at first and wrote above message. False alarm. Have a nice day.
                                  PS: Really good topic with pics. Thanks to razor_amd.
                                    • 20571
                                    The external images have been added to badcaps. Thanks for the VPN explanation.We do ask members to add their images to badcaps as external image hosts can go offline or close down.
                                    • Kemer
                                      • Apr 2023
                                      • 37
                                      • Turkey
                                      That link needs update.
                                      How can we understand if is this DMI data start? Is this adress a standard for all bioses?
                                      Why 2KB? Exactly 2048 bytes? I see "delete" till 0x7F0 in last picture. That is 2032 bytes.
                                      I read the topic in win-raid which shown in OP (D3. ME 7 - 10 & TXE 1 - 2) but also couldn't understand how to find DMI start or where and how many bytes should delete. Can anyone please clarify? Thanks
                                        • 20571
                                        There are more broken win-raid links besides that one,they will all be updated.. soon
                                        No the addresses are different
                                        The end address is 7FF
                                        The win-raid guide is only for ME firmware it does not go into the subject of copying DMI, razor_amd mentions it in his guide. DMI addresses are in different places. There are some Asus DMI tools available if you can`t use a hex editor https://www.badcaps.net/forum/showpo...43&postcount=5
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • caglarec2268
                                          Asus X515EA Bios File Please
                                          by caglarec2268
                                          merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                          Now "please follow the steps below to recover your bios" text remains on the screen
                                          I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                          laptop model x515ea-bq945w
                                          s/n: R4N0CV02K527148
                                          CN:HWFB
                                          Board model; ASUS X415EA R7.0
                                          bios chip: GD25Q128...
                                          11-27-2024, 03:51 AM
                                        • wakethesleep1111
                                          Bios File Needed for asus tuf15
                                          by wakethesleep1111
                                          Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                                          05-27-2025, 10:56 PM
                                        • rickjansen01
                                          Asus FA707 corrupt Bios File
                                          by rickjansen01
                                          Hello Guy's
                                          Can somebody help me whit this problem
                                          Asus FA707 bios file is corrupt
                                          sn T3NRCXCZR00Y117
                                          original file uploaded
                                          Regards chris...
                                          04-20-2025, 07:12 AM
