BIOS file for ASUS F542UN laptop
  • Sebastian Codrean
    • Feb 2025
    • Romania
    Hello to all of you! I need help with a BIOS file.
    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
    • 22011
    Type as text the laptop serial number that is on the case label. Is X542UN on the long white barcode sticker on the motherboard
    • Sebastian Codrean
      • Feb 2025
      • Romania
      I think this is the serial no: J7N0CV02036328D
      I also atached the pictures of both labels
      • zdargh
        Asus laptop g14 GA401IH bios
        by zdargh
        Asus Laptop G14
        Motherboard model: GA401IH
        Rev 1.1
        Motherboard Part Number: 60NR0480-MB1203
        Serial Number: L731NRKD0006K1MB
        The computer shut down during a bios update and went into a boot loop. I've been able to backup the bios and flash a new bios (from the asus website, the ez flash update) using a SPI programmer. I got it to the point where it'll stay on for a few minutes before restarting and going into a boot loop that gets shorter and shorter.
        I've been able to factory reset it, but once I unlock the laptop and get to the desktop screen - the bootloop...
        07-21-2024, 07:33 PM
      • vixeko_
        Problems with the asus x456ua laptop bios chip
        by vixeko_
        They asked me to change the HDD to an SSD on this Asus laptop, in case the laptop already had problems such as it not turning on every time and the battery charge lasting very little.
        and perform the task successfully and clone the data from the hdd to the new ssd
        I managed to start windows on the ssd and everything was normal so I decided to restart it to measure the startup speed and when I did that instead of starting windows the laptop sent me to the bios
        I exited the bios to continue to windows but when the laptop turned off it did not turn on again, it was strange but...
        10-19-2023, 06:36 PM
      • Food1244
        Gm501gm Bios laptop asus
        by Food1244
        I recently enabled secure boot and disabled csm on my laptop in the bios.
        Immediately it stopped working. Black screen (no backlight) , keyboard rgb worked, fan turned on. Battery led would flash 3 times then repeat.
        I got a ch341a reader thinking it's not posting so mightve corrupted the bios.
        The files I have are attached. One of the bios from the Asus website and one of what I got from the laptop chip (backup).
        Please help me use these to make a new bios I can use to get this to work...
        06-29-2025, 08:32 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
