Bios File Needed for asus tuf15
  • wakethesleep1111
    • May 2025
    • 11
    • US
    Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
  • bbanana
    Father Land
    • Oct 2021
    • 164
    • Vietnam
    what's your serial number?
    • wakethesleep1111
      • May 2025
      • 11
      • US
      my serial number is MBNRCX05N869476
      • peste
        • 13931
        • ROMANIA
        post the contents of the bios chip even if it is corrupted..
        • wakethesleep1111
          • May 2025
          • 11
          • US
          Ok so idk if this is normal but i did erase it at one point in this process but the only data i can get to shoe up now is zeros.
          Do u want me to post the exact contents? If so ill do so as soon as i get home from work
          • wakethesleep1111
            • May 2025
            • 11
            • US
            Okay sorry about the delay but this was the data I had on the bios before I possibly erased it. So the original data. And I am mainly in need of removing the bios lock. The file is attached in a txt file.
            • wakethesleep1111
              • May 2025
              • 11
              • US
              Is the data acceptable in a .txt format? If not what format shall I put it in?
              • LEO037_2029_
                BIOS_LEGEND
                • Nov 2023
                • 83
                • Argentina
                @wakethesleep1111​ attach your bios backup inside in a WINRAR and upload here.
                • wakethesleep1111
                  • May 2025
                  • 11
                  • US
                  Here is my bios bin as requested.
                  • LEO037_2029_
                    BIOS_LEGEND
                    • Nov 2023
                    • 83
                    • Argentina
                    @wakethesleep1111 here ts the password four your laptop
                    - Admin Password : 28GV562956bwh
                    - Boot Password : 28GV562956bwh
                    good luck. try and feedback
                    • wakethesleep1111
                      • May 2025
                      • 11
                      • US
                      unfortunately it did not work but is it either possible to remove the password from the bios file by editing it with hex editor and uefi tool then reflashing it? or do you know where a fresh bios file for this exact model is exists which is a TUF506LH motherboard model is DABKXDTB8C0
                      • peste
                        • 13931
                        • ROMANIA
                        the password above should work, try again...if it doesn't work try this...
                        try..
                        • wakethesleep1111
                          • May 2025
                          • 11
                          • US
                          I appreciate the help but this bios bin did not work either. My laptop is basically bricked with this bin flashed. Ofcourse I have the original locked one so I can return it to that so its not bricked permanently. So for some reason my exact model doesn't have a bios bin available for it from the manufacturer but I want to try flashing an fresh bin so I guess I have to try to find one. Do you have an idea where I might find one?
                          • wakethesleep1111
                            • May 2025
                            • 11
                            • US
                            It's kinda strange the password didn't work. This laptop is a challenge it seems like. I am not sure what to do if all fails. Even if I replace the whole chip I still have to flash a new bin on it right? which I can not find.
                            • wakethesleep1111
                              • May 2025
                              • 11
                              • US
                              did you have the tested and working clean or fresh bios bin to my bios? i am still strugglin
                              • to5it0
                                by to5it0
                                10-24-2025, 01:35 AM
                              • Sebastian Codrean
                                BIOS file for ASUS F542UN laptop
                                by Sebastian Codrean
                                Hello to all of you! I need help with a BIOS file.
                                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                02-20-2025, 10:25 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • kodox
                                Asus ExpertBook B1400CB Bios Dump Needed
                                by kodox
                                need original bios dump, original bios has flashed by other technician before me.
                                attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                unit info:
                                Model: Asus ExpertBook B1400CBA-0711A1235U
                                S/N: R6NXNZ006657238
                                CN: 7F6F
                                Mainboard Code: B1500CBA R2.1...
                                08-16-2025, 12:20 PM
                              • caglarec2268
                                Asus X515EA Bios File Please
                                by caglarec2268
                                merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                Now "please follow the steps below to recover your bios" text remains on the screen
                                I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                laptop model x515ea-bq945w
                                s/n: R4N0CV02K527148
                                CN:HWFB
                                Board model; ASUS X415EA R7.0
                                bios chip: GD25Q128...
                                11-27-2024, 03:51 AM
