Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Try this
1. Decompose the BIOS image with FIT 16.1 (drag and drop)
2. In Build Settings - Build results, you can change the "Output path" and "Output Config XML path" filenames
3. Press "Save config", and close FIT
4. Extracting the ME region update from the ASUS provided BIOS update
4.1. Open X1502ZAAS301.bin from ASUS website with UEFITool.
4.2 Go to the last GUID, expand it, then expand the GUIDs until you see "LZMACustomDecompressGUID - Raw section", Right Click- Body hex view, should look like this:
4.3 Right click the same "Raw section" - Extract body, save as a new file, example: "MEupdate.bin"
4.4 Open FIT, and drag and drop "MEUpdate.bin", it will decompose in "MEUpdate\Decompose" folder and you get "ME Sub partition.bin", close FIT
5. Grab the "ME Sub partition.bin" and replace it on X1502ZAAS301NEW\Decompose folder
6. Open FIT, Load previous layout's configurations, select the .xml you saved on steps 2-3
7. Build the image, you get 2 warnings which are normal
First of all, I'd like to wish everyone the best. I can now create a BIOS file using the method described above, and there's no problem. However, I need to perform a Clean ME. I couldn't perform a Clean ME with version 16.1 of the Modular Flash Tool. First, when I copied the ME file to a folder, renamed it, and hit Build, I got another error. I found a 5-minute video online. It showed me that I needed to add the MFS and EFS sections to the BIOS file I needed to clean ME, so I added them. However, when I tried to build again, I got the error "Exception: Data bucket: 'OEM_KM'. Error: 'The public key in the OEM Key Manifest provided does not match the hash provided in CsePlugin:UEP:OemPublicKeyHash'.
Source: 'CsePlugin:OEM_KM'". Can someone help me with this?Leave a comment:
Okay, I got it done. I just had to drag it, I was trying to open it by saying open.
* I prefer not to jump to latest BIOS version, find which version you have first, rebuild it, then update BIOS with EZ-Flash, search for X1502ZA, until you see something like this
In this example BIOS version is 300, download from https://www.asus.com/supportonly/f1502za/helpdesk_bios/ , click on "Show all"
For Intel CPU, you need a backup of the BIOS chip, make sure you get a good backup first, as we'll graft a new BIOS region to it
1. Use https://github.com/platomav/BIOSUtilities , install all the prerequisites
It will extract to a folder X1502ZAAS.319_extractedCode:main.py X1502ZAAS.319
2. Open "00 -- ALL" with hex editor, you have to cut it to the size of the BIOS region (for this model length is A00000, from 0 to 9FFFFF)
3. Make a copy of the BIOS backup you read with programmer, we'll graft the BIOS region to it
4. Find where the BIOS region starts, you can use UEFITool NE to open it, it's at 600000, length A00000
5. Paste write the selection from step 2 starting at offset 600000, on the copy of the BIOS backup (keep the original safe)
6. Open the original BIOS backup, search for GPNV, select from 660000-66FFFF on this model, copy/paste write to the "new" BIOS; that's the DMI area, it also has the Win license key
7. Save the new modified BIOS (Save as... new name)
8. Hope your ME region is intact, or less than equal to 16.1.25.2091, if it's higher the latest publilcly available FIT 16.1.25.2091 may not be able to decompose it
Latest ME Analyzer https://github.com/platomav/MEAnalyz.../v1.309.0-r375 should work (but it will say "Error: Unsupported Intel Engine, Graphics and/or Independent firmware!"), you have ME 16.x.yy.zzzz; ME version from the BIOS update you linked is 16.1.35.2557; unfortunately latest "public" FIT 16.1.25.2091 can't decompose later version
Post your BIOS backup on the X1502ZA thread if you need help, here: https://www.badcaps.net/forum/troubl...6-asus-x1502za
(ASUS is a bit weird, they rename the same laptop, yours is F1502ZA but uses X1502ZA BIOS)
Sorry to bother you again. I was able to get a proper bios by doing what you said, but I could not find the fit 16.0.15.1735 version. The modular flash version, which is 16.1, also gives an error. Is there another way to clean the me area?
Attached FilesPremium supporters get full download access and other benefits.
Thank you so much for the valuable information you provided. I didn't know I needed to remove it with BIOS utilities. It automatically deleted the parts that should have been removed, so I had no problems. Thank you so much for your experience and helpful information. I will never have problems with this bios again.
(ASUS is a bit weird, they rename the same laptop, yours is F1502ZA but uses X1502ZA BIOS)Last edited by m1ch43lzm; 11-30-2025, 01:40 PM.Leave a comment:
First of all, good luck to everyone, you have shared nice posts for these models, but in the new versions, I cannot edit or extract the bios files I downloaded from their website. I tried it with Hxd, ami extractor etc. and the uefitool program shows it as multi-part. Any me anlayzyer program does not show what is happening. That's why I don't know which version of flash image tools can open them or whether they can be opened, and I can't extract them from the bios I downloaded from the site. Can someone please tell me how to do this? I added a sample file
SN : N8N0CV05N037320
F1502ZA
My question is.
1. I have previous bios dump but ( may be someone flashed bios directly downloaded from asus site) but I dont have any data.
No ME, UUID, MAC nothing I can extract from previous bios hence the mobo is dead rn and I want to revive it.
What to do now?
see attachment.Leave a comment:
You`re right that its no longer applicable on many Asus models,but there`s still some useful info. All the other guides will become outdated as well over time.Its up to our members to write newer guides,we will gladly sticky them in the Bios guides thread.I am not a bios expert but as many have seen, the guide in question is no longer applicable on many Asus models. For example, Asus provides files that appear to only need to be changed in size but which are actually encrypted. The model on which the guide is based is now many years old and many things have changedLeave a comment:
Use the next oldest or newer consumer version H .Using a slightly older/newer one is usually ok -
If my ME analyzer say vers 14.0.33.1125 and i need the RGN version but the unique version that have rgn is the corporate verion whta i need to do? in consumer version H
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by vic6688Hello everyone,
I would like to ask for your help with my ASUS desktop.
Model:
ASUS ExpertCenter D700SA
BIOS:
AMI Aptio V
BIOS Flash:
Winbond W25Q128JV (16MB)
I forgot the BIOS Administrator password.
I have already read and verified the complete BIOS dump using a CH341A programmer, and I have attached the original 16MB BIOS dump.
If possible, I would prefer to recover or identify the current BIOS password so that I can continue using the original BIOS without reflashing.
If...-
by bilenI don't have the motherboard's original BIOS file; it came to me having already been tampered with. I need a file extracted from the Asus website that is confirmed to be the original and fully functional.
İ9 13.GEN CPU
Motherboard code : G634G-PMV-VGT 6050A3441302-MB-A01 2023-02-10
Full model : G634JZ-NM043-Gaming
Serial no: R6NRKD03398224E-
- Loading...
