NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
hi tryAttached FilesComment
I have Hp Elitebook 840 g5 it turns normally but shows an error message "END POINT SECURITY CONTROLLER PROBLEM"
Please some should help me remove the end point error, i will attach the main and ec bin here
S/N: 5CG038BBNM
MODEL: Hp Elitebook 840 G5
P/N: 6050A2945601-MB-A01Attached FilesComment
S/N: 5CG038BBNM
yet diplay then ty ths endpoint eror solveAttached FilesComment
hello guys, i have an issue with my 840 g5, its not detecting SSD, i did everything, i changed ssd, even i replaced ssd jack too, i checked all pins of ssd jack, and getting proper volts and signals, i think its bios issue,
also i tried to update bios from bios menu, its saying "Bitlocker drive encryption (BDE) is enabled on your system using TPM security", i think its bios issue, could anyone help me please
SN#5CG82302YN
Please I need help with my bios for Hp 840G5, I have programmed almost all bios file and EC file on this thread, none seems to work, I have been having different error light, some point bios corruption, and other bios and EC mismatch. Please help me with a working file please. Here is the backup of my ec and bios file
My laptop is
Hp Elitebook 840 G5
Core i5 8th generation
Model: HSN-113C-4
ProdID: 5JM99EC#ABH
SN: 5CG9062P70
My laptop is
Hp Elitebook 840 G5
Model: HSN-113C-4
ProdID: 5JM99EC#ABH
SN: 5CG9062P70
here you got two dumps (EC+BIOS) but you need to use BCU tool to enter factory data ... from your provided bios content is this:
Description: HP EliteBook 840 G5
Serial Number: 5CG8180LLR
Product Number: 2FA66AV
Board CT Number: PGWHT00WBAR2GG
BuildId(BID): 17WWCSAT601#SABH#DABH
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhk.hy
MAC Address: B4-B6-86-8C-A2-6F
Good Luck!Attached FilesComment
First , you must check all components near the EC and BIOS chips to ensure you have not blow out any little resistor and second sometimes it takes a long time to boot for the first time after flashing both EC and BIOS and I mean even up to 5-10 minutes with several restarts.
That dumps worked for me on several 840 G5 laptops.
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
