NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • alontest
    • Aug 2018
    • 20
    • nowhere
    #521
    Originally posted by shiyab
    post both file 16mb ec
    Here you go, thank you
    • shiyab
      • Sep 2023
      • 1444
      • india
      #522
      hi try
      • alontest
        • Aug 2018
        • 20
        • nowhere
        #523
        hi try
        Hi thank you, is it enough just ec ? Asking as it requires full strip here and there to test
        • Zillions Tech
          • Jul 2022
          • 24
          • Nigeria
          #524
          I have Hp Elitebook 840 g5 it turns normally but shows an error message "END POINT SECURITY CONTROLLER PROBLEM"
          Please some should help me remove the end point error, i will attach the main and ec bin here
          S/N: 5CG038BBNM
          MODEL: Hp Elitebook 840 G5
          P/N: 6050A2945601-MB-A01
        • shiyab
          • Sep 2023
          • 1444
          • india
          #525
          S/N: 5CG038BBNM
          hi try
          • Zillions Tech
            • Jul 2022
            • 24
            • Nigeria
            #526
            hi try
            Not work, thank you
            comes up no display
            • AHSAN TARIQ
              • Jan 2025
              • 60
              • Pakistan
              #527
              Not work, thank you
              comes up no display
              YOUR PREVIOUS BIOS DISPLAY YET ORNOT
              • AHSAN TARIQ
                • Jan 2025
                • 60
                • Pakistan
                #528
                Not work, thank you
                comes up no display
                yet diplay then ty ths endpoint eror solve
                • han19977
                  • Sep 2021
                  • 15
                  • Pakistan
                  #529
                  hello guys, i have an issue with my 840 g5, its not detecting SSD, i did everything, i changed ssd, even i replaced ssd jack too, i checked all pins of ssd jack, and getting proper volts and signals, i think its bios issue,
                  also i tried to update bios from bios menu, its saying "Bitlocker drive encryption (BDE) is enabled on your system using TPM security", i think its bios issue, could anyone help me please
                  SN#5CG82302YN
                  • winix
                    • May 2023
                    • 4
                    • Nigeria
                    #530
                    Please I need help with my bios for Hp 840G5, I have programmed almost all bios file and EC file on this thread, none seems to work, I have been having different error light, some point bios corruption, and other bios and EC mismatch. Please help me with a working file please. Here is the backup of my ec and bios file
                    My laptop is
                    Hp Elitebook 840 G5
                    Core i5 8th generation
                    Model: HSN-113C-4
                    ProdID: 5JM99EC#ABH
                    SN: 5CG9062P70
                    • Stefan Steff
                      • Mar 2024
                      • 249
                      • Romania
                      #531
                      My laptop is
                      Hp Elitebook 840 G5
                      Model: HSN-113C-4
                      ProdID: 5JM99EC#ABH
                      SN: 5CG9062P70
                      Your provided serial does not match any of the dumps provided...in fact the two dumps are from different laptops...anyways,
                      here you got two dumps (EC+BIOS) but you need to use BCU tool to enter factory data ... from your provided bios content is this:
                      Description: HP EliteBook 840 G5
                      Serial Number: 5CG8180LLR
                      Product Number: 2FA66AV
                      Board CT Number: PGWHT00WBAR2GG
                      BuildId(BID): 17WWCSAT601#SABH#DABH
                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhk.hy
                      MAC Address: B4-B6-86-8C-A2-6F
                      Good Luck!
                      • winix
                        • May 2023
                        • 4
                        • Nigeria
                        #532
                        Thank you so much for your swift response. I appreciate it so much.
                        So after flash the EC & Bios you provide, I get a steady white light with 11 amber then 6 amber blinking then restart.
                        Please kindly help me in anyway you can. Thank you
                        • Stefan Steff
                          • Mar 2024
                          • 249
                          • Romania
                          #533
                          That dumps worked for me on several 840 G5 laptops.
                          First , you must check all components near the EC and BIOS chips to ensure you have not blow out any little resistor and second sometimes it takes a long time to boot for the first time after flashing both EC and BIOS and I mean even up to 5-10 minutes with several restarts.
                          Click image for larger version  Name:	EC.jpg Views:	0 Size:	501.5 KB ID:	3695808 Click image for larger version  Name:	BIOS.jpg Views:	0 Size:	203.6 KB ID:	3695809
                          • STKR123
                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                            by STKR123
                            Greetings badcaps community,
                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                            I learned that desoldering...
                            10-29-2024, 06:03 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Guest
                            Elitebook 850 G5 BIOS bricked
                            by Guest
                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                            I assume the BIOS update failed, so I searched for the BIOS chip.
                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                            Can the corrupted...
                            03-24-2025, 01:21 AM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
