Need Lenovo E590 NM-B911 bios dump
  • bmb2015
    • Jul 2023
    • 10
    Re: Need Lenovo E590 NM-B911 bios dump
    Thanks for the screenshot, I don't have the BIOS chip in that location. Motherboard is FL490 /FL590 NM-B931 Rev 1.0 2019-03-15
    I attached pics if it helps. Basically the chip I referenced is left of the bottom screen hinge.
      • 22227
      There`s another thread for NM-B931 bios requests,post there -> https://www.badcaps.net/forum/showthread.php?t=113901
      • bmb2015
        • Jul 2023
        • 10
        I just found the bios chip. It is Winbond 25Q256JVEQ. It is a low profile one next to the WAN card. I can't get my CH341 clamp to make connection because the chip legs are much shorter.
        Since this is a general question for this thread: Aside from desoldering and resoldering, do you know of any product that can attach to the bios chip with small connector?
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #44
          https://www.badcaps.net/forum/showth...99#post1234299
          Become a Badcaps supporter
          Thanks to all supporters.
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            #45
            come on, man! it's where I pointed it, only my pic is upside down! Use thread for L590 indicated by SMDFlea, this thread is for E590.
            • bmb2015
              • Jul 2023
              • 10
              You are absolutely right about the location of the chip in the picture you attached. To my eyes it wasn't that clear because the legs of my particular chip are not as long. My existing CH341 programmer clip can't make contacts with it so I ordered micro clips to attach as opposed to desoldering and soldering.
              Didn't mean to disrespect. I just didn't see it properly.
              • grigoras1973
                • Nov 2019
                • эстония
                #47
                Originally posted by brontobyte
                SN PF-1RTGCS
                Laptop turn on, 3 restarts, no fan, only 0.07Ah on 20v. Power light on
                i have 3.3 on bios chip, 1.05 on pch coil 3,3v on SIO chip.
                no voltage on vcore
                How did you solve this problem? I have the same problem .
                • grigoras1973
                  • Nov 2019
                  • эстония
                  #48
                  I have a Thinkpad E590.Help me clean the BIOS.
                  Type is: 20NB-0029GE
                  Serial is: PF-1Y3N10
                  Motherboard: NM-B911 Rev 2.0
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    Read the rules before posting:
                    • VUONG MAI
                      • Dec 2022
                      • 15
                      • Viet Nam
                      #50
                      Please help me ! this bios is stuck on lenovo logo.
                      Type : 20N8-S0CJ00
                      S/N : PF-1YX4K9
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12431
                        #51
                        Type : 20N8-S0CJ00
                        S/N : PF-1YX4K9
                        This's topic for E590
                        • hyditech
                          • 272
                          • nigeria
                          #52
                          please i need help on how to successfully removed bios password on LENOVO E590
                          With board number NM-B911
                          I have try it using the python,BUT after programming it will be making sound and wont display. But if i return the original bios it will display
                          please is there any other way out
                          thank you,
                          • techrecycle
                            • Jan 2024
                            • 64
                            • england
                            #53
                            LENOVO E590 BIOS PASSWORD
                            SN: PF13M2GW
                            PLEASE HELP THANKS
                            • bzzt
                              • Jun 2023
                              • 11
                              • Netherlands
                              #54
                              Could someone have a look at this dump?
                              Startup error melody 0285 "TCG-compliant functionality-related error(might be the TPM initialization failure". Laptop behaves differently with other bios'es, but I'm not certain if this is the issue, seems fine hardware-wise.
                              Thinkpad E590 20NB-A001MB
                              Board Nr NM-D911 REV 2.0
                              S/N PF-1XXALX
                              • qayyum786
                                • Aug 2018
                                • 1959
                                • INDIA
                                #55
                                S/N PF-1XXALX
                                try a new one
                                • bzzt
                                  • Jun 2023
                                  • 11
                                  • Netherlands
                                  #56
                                  Originally posted by qayyum786
                                  try a new one
                                  Thank you! Turned on then shut down, didn't reboot. Manually press power button and rebooted twice and stays on, the CPU isn't getting warm though, no display.
                                  UPDATE: Skill issue, loose resistor. Your BIOS worked like a charm.
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    #57
                                    Five
                                    ​star for honest review
                                    • hova
                                      • Jan 2024
                                      • TOGO
                                      #58
                                      i need hp pavilion 11-h110nr bios model boad a0w03mbai0
                                      • qayyum786
                                        • Aug 2018
                                        • 1959
                                        • INDIA
                                        #59
                                        Off topic
                                        start a new request with your model number ad serial number and describe your issue ( problem ) as well from BIOS Requests ONLY! +New Topic
                                        • pic16f84a
                                          • May 2022
                                          • 12
                                          • España
                                          #60
                                          Greetings, someone can repair the bios of Lenovo E590? It is corrupted and I can't find a stable bios. The motherboard is FE490/FE590/FE480 NM-B911 Rev 2.0. Integrated intel graphics.
                                          Type 20NB-002BSP
                                          S/N: PF-1XGJ5V
                                          Thank you very much​
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            ✅ What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
