HP EliteBook 845 G7 BIOS Pass
  • dkmaj1
    • Jul 2025
    • 4
    • PHILIPPINES
    #201
    Can someone help me remove the password?
    • peste
      • Dec 2016
      • 13653
      • ROMANIA
      #202
      post S/N, full name and model, motherboard model, product number,etc.
      • shiyab
        • Sep 2023
        • 1620
        • india
        #203
        Originally posted by Echoo
        Hello!
        Can someone please remove the password? Thank you very much!
        HP 845 G7
        SN: 5CG0529Y3Q
        ProID: 8VZ06AV
        MB: LINDEN-6050A3147201-MB-A01(A1)
        hi try
        • dkmaj1
          • Jul 2025
          • 4
          • PHILIPPINES
          #204
          Can someone help me remove the password? This is the stock bin file from the bottom chip.
          HP ELITEBOOK 845 G7
          S/N: 5CG1160KY3
          ProdID: 33K13PC#UUF
          MOTHERBOARD: LINDEN-6050A3147201-MB-A01 (A1)
          • shiyab
            • Sep 2023
            • 1620
            • india
            #205
            hi try
            • dkmaj1
              • Jul 2025
              • 4
              • PHILIPPINES
              #206
              Originally posted by shiyab
              hi try
              Thank you. I compare it to the one I edited using HxD, and it says its the same, so I guess we edit the same thing on the file. However, already did try this and it's still asking for bios password.
              Also, should I boot the laptop to bios first ? or its just fine to boot it normally, because in my case it boot normally first, and when I boot to bios its still asking for Password, and try to read the bin file again, and the hex/code revert back to stock.
              • Echoo
                • Apr 2018
                • 92
                • Budapest
                #207
                hi try
                Thank you very much! Excellent!
                • voodoop
                  • Jul 2019
                  • 24
                  • Romania
                  #208
                  Hi !
                  Can anyone repair my BIOS ?
                  HP Elitebook 845 G7
                  ProdID : 2E1J9UC#ABU
                  Warranty : 3y3y0y
                  SN : 5CG0521016
                  Thanks !
                  • peste
                    peste commented
                    Editing a comment
                    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                • kingkong computers
                  • Sep 2018
                  • 211
                  • pakistan
                  #209
                  PLEAS ULOCK
                  HP ELITEBOOK 845 G7
                  S/N: 5CG1161Z79
                  ProdID: 3A6N3EC#ABD
                  • dariuxzy
                    • Mar 2023
                    • 44
                    • italy
                    #210
                    Hi, I backed up main BIOS (Winbond 25Q256JVEN, HP ELITEBOOK 845 G7) and I tried to removing the password in HxD, but I can't find NvramActiveRegn between lines 00037000 etc... as if the password wasn't there. BUT actually it's asking for it. Can anyone help me? Thanks.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12339
                      #211
                      HP EliteBook 845 G7 Notebook PC
                      Serial_2TK13100N6
                      Product_1V4L6AV
                      Build Id_20WWLDDT601#SABA#DABA
                      Fearture byte_3X476J6S6b7B7H7M7Q7W7m7s8uaBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnW.D3
                      * NvramActiveRegn is in the EC chip.
                      • dariuxzy
                        • Mar 2023
                        • 44
                        • italy
                        #212
                        Serial_2TK13100N6
                        Product_1V4L6AV
                        What's the difference between this file you sent me? Do I have to flash it? Thanks
                        • dariuxzy
                          • Mar 2023
                          • 44
                          • italy
                          #213
                          hoaca388 please, can you tell me if I need to flash the file you shared? I don't understand, or do I have to extract the EC chip to remove the password? Thanks for the clarification
                          • Hachem25
                            • Aug 2021
                            • 52
                            • algeria
                            #214
                            hello, after an incompleted bios update this hp elitebook 845 g7 stopped working normally. now it gives the endpoint error then keep rebooting to the same error with fan at max.
                            SN: 5CG1158TXQ
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12339
                              #215
                              SN: 5CG1158TXQ
                              Decription_HP EliteBook 845 G7 Notebook PC
                              Serial_5CG1158TXQ
                              Sku_2H0J3UC#ABA
                              Build Id_20WWLDCT601#SABA#DABA
                              Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPfXguhKhkjhk8mEmV.yd
                              • Hachem25
                                • Aug 2021
                                • 52
                                • algeria
                                #216
                                Serial_5CG1158TXQ
                                Sku_2H0J3UC#ABA
                                tahnk you it worked as a sharm. i still have a problem of missing hosted factory mac adderess. even after using bcu i couldnt find it. also in advenced bios settings it shows as 00
                                • lex00
                                  • Apr 2020
                                  • 10
                                  • Russia
                                  #217
                                  PLEAS ULOCK bios pass
                                  HP ELITEBOOK 845 G7
                                  S/N: 5CG051226R
                                  ProdID: 2M5C3ES#ABD
                                  • Hachem25
                                    • Aug 2021
                                    • 52
                                    • algeria
                                    #218
                                    unfortunately after a bios update the laptop now keeps restarting and no display the capslock light stays on all the time even when the laptop is off.
                                    • STKR123
                                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                      by STKR123
                                      Greetings badcaps community,
                                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                      I learned that desoldering...
                                      10-29-2024, 06:03 AM
                                    • Wutru
                                      HP Elitebook 820 G4 BIOS repair assistance required
                                      by Wutru
                                      Hi guys,
                                      If someone would be able to provide some expertise, I'd be very grateful.
                                      BIOS Corruption - Cause
                                      So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                      After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                      09-06-2025, 10:32 AM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • jotati7062
                                      Hp Elitebook 860 G10 Admin/bios Pass
                                      by jotati7062
                                      Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                      i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                      08-13-2025, 04:33 AM
                                    • zlr8r
                                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                      by zlr8r
                                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                      cheers
                                      Dell Inspiron 17 (7786) Laptop
                                      Service Tag: 5J0NHT2
                                      Bios: 1.9.0
                                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                      Attached;
                                      1. My saved bios using a programmer
                                      2. Dells Bios updater .exe (v1.16)
                                      3. Dells Bios recovery file
                                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                      5. Image of ME...
                                      12-18-2023, 03:08 PM
