HP EliteBook 845 G7 BIOS Pass
  • Mijgan
    • Dec 2011
    • 6
    #41
    Re: HP EliteBook 845 G7 BIOS Pass
    Today i updated my CH341A programmer (3.3v FIX). I'm using other software for read BIOS chip, but reading data absolutely identical with files read earlier.
    • Mijgan
      • Dec 2011
      • 6
      #42
      Hello, sorry for my english. I soldered the chips back to the board, the laptop did not start, I looked at the board again and found that the sixth pin was soldered on one of the chips. After the soldering, everything started and, lo and behold, the admin password disappeared, but the Endpoint Security Controller inscription appeared. In any case, it's better than not having access to BIOS settings. Now everything works except this warning at startup.
      • guzmanja75
        • Apr 2019
        • 3
        • spain
        #43
        if you modify the main bin (unlock) and then write it back, the ec chip sees that it has been played with, then it puts the old backup back with password back in, the newer hp you should not do the old way, this gives these problems and many errors
        • mferna14
          • Jun 2018
          • 1020
          HI all, Working on HP EliteBook 845 G7 but it is bios password protected hp laptop & can't get it to unlock. I have uploaded the original 256MB Bin Files, can anyone kindly remove the BIOS ADMIN Password. Thanks in advance
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #45
            Upload the dump from the second bios chip.
            Become a Badcaps supporter
            Thanks to all supporters.
            • mferna14
              • Jun 2018
              • 1020
              Thanks Vesko356..., here you go the Bin dump on the second chip... There are 2 location #s on this U365 & U366, anyway only one chip present
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #47
                Program only this (second) chip with the attached file, the other stays as is.
                • mferna14
                  • Jun 2018
                  • 1020
                  Sir, thank you very much... will do so & Inform you after all is done.
                  • mferna14
                    • Jun 2018
                    • 1020
                    I programmed just the second BIOS chip with updated Bin files you send me, but no luck. Now what happens is the LED on the power jack blinks 5 times fast & stops & then again blinks 5 times & stops & this keeps on going in a loop till I remove the power cord. It does not turn on at all even after pressing the power ON/OFF button on the keyboard. Kindly re-check please. Before this all was working fine except for the ADMIN BIOS Password. Thanks
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #50
                      Check the content of the chip, did you use verification? Also check the soldering of the chip and nearby components, make sure you didn't knock of resistor or something else at the surrounding area.
                      Edit: also check the soldering of the other chip.
                      • mferna14
                        • Jun 2018
                        • 1020
                        Yes, it did a Flash verification after programming was complete, I did not do a verification later, I will do all what you told me & get back to you... Thanks
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #52
                          The safest method for verifying the contents is to read the chip after programming and compare the resulting file with the source. This eliminates any doubt, and you can proceed to soldering the chip to the board.
                          In this way, each step of the process is verified, and in the event of a problem, only the last step can be checked - namely the soldering to be inspected.
                          Otherwise, everything has to be done again from the beginning, because it is not certain at what stage the mistake was made.
                          This also applies to the initial reading of the chip with the original (containing the password) dump. Two or three content dumps need to be made that are compared to each other. If they are the same then it is certain that the content has been read correctly.
                          The procedures described above can take five minutes longer, but save five hours of headaches.
                          • mferna14
                            • Jun 2018
                            • 1020
                            Sir, after writing/flashing the chip it says programming successful & Auto Verification Success., but when I again verify the flash BIOS, it gives me errors, why is this so??? I even changed with another Brand New 25Q256JW , still the same error. Thanks for the reply in advance.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #54
                              Read again my previous post, do not rely on a automatic verification process built into the software.
                              Check the contact between the chip and the adapter
                              • mferna14
                                • Jun 2018
                                • 1020
                                Sir, I checked all the contacts on the chip & they are fine & no knocked off components. I have no idea why I am get the verifaction error over & over again. I took another Physical Programmer CH341A. It writes well but upon verification, it gives Verification errors too. So as you told me, I did a manual Verification off the BIOS Chip dump & the bin file you send me. EXCATLY THE SAME in HxD. Upon this verification I was satisfied & soldered the flashed chip on the motherboard. All worked fine without any Admin Password. Thanks you Very much Vesko256 for your GREAT HELP/WORK. It was very nice & kind of you to take out time & remove the Admin PW. 100% Works. Thanks
                                • sarkov
                                  • Aug 2016
                                  • 12
                                  • Spain
                                  #56
                                  Good afternoon, I have an HP 845 G7 from which I am not able to remove the MDM, could you help me to remove it?
                                  Thank you
                                  • GabyCR
                                    • Mar 2015
                                    • 30
                                    • España
                                    #57
                                    Hi guys,
                                    is someone so kind as to remove the admin pass from this bios?
                                    Thank you very much
                                    • peste
                                      • Dec 2016
                                      • 12806
                                      • ROMANIA
                                      #58
                                      Originally posted by GabyCR
                                      Hi guys,
                                      Thank you very much
                                      the password is in the 16MB bios..so look for a 16MB chip on the motherboard and post the content ..
                                      • GabyCR
                                        • Mar 2015
                                        • 30
                                        • España
                                        #59
                                        Thank you very much for your reply!
                                        I can't find any with 16mb, I have two chips, one on each side of the board, I attach the two bios.
                                        Thank you very much!
                                        • peste
                                          • Dec 2016
                                          • 12806
                                          • ROMANIA
                                          #60
                                          yes..this has two 33 Mb..write only on this the first one stays the same ..
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • what_1282105
                                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                            by what_1282105
                                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                            02-14-2025, 07:27 PM
