Macbook Pro A1706 EMC 3163 820-00923-A pass pleas
  • Mrnixdorf
    • Sep 2016
    • 120
    • Morocco
    #41
    Re: Macbook Pro A1706 EMC 3163 820-00923-A pass pleas
    im having the same issue after removing password doesn't see storage and when I boot from internet recovery give me iCloud pin thank in advance
    • peste
      • Dec 2016
      • 12742
      • ROMANIA
      #42
      try..
      • Mrnixdorf
        • Sep 2016
        • 120
        • Morocco
        #43
        Thank you
        • fiabo89
          • Nov 2019
          • 14
          • Italia
          #44
          hi can you remove passcode please? thanks
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #45
            Unlocked:
            Become a Badcaps supporter
            Thanks to all supporters.
            • mferna14
              • Jun 2018
              • 1018
              Dear People., Kindly clean this BIOS of my Apple Laptop MacBook Pro A1706 EMC 3163 S. NO: C02V68DNHV2L . The laptop is very clean, it's just stuck on 5v, No short & no liquid spills. I am assuming that this maybe the BIOS problem. I get 3.2V near the MUX chips caps. Kindly someone cleanme the BIOS, would appreciate. I have attached the Original BIN file. Thanks in advance
              • hardware1
                • Sep 2021
                • 2930
                • N/A
                #47
                Here is your clean BIOS, try it.
                all donations are welcome,
                • mferna14
                  • Jun 2018
                  • 1018
                  Thank you so very much "Hardware1"., will surely let you know. Is there a link where we all can do this cleanme by ourselves & learn how to do it? I was trying to do the cleanup with the MacBook Air A1466 BIOS cleanup process, but this Bios Bin file did not recognize in the Intel Cleanme program. It is very kind of you to take all this time & do it for us. Thanks in advance.
                  • Expired
                    • Feb 2023
                    • 34
                    Take a look at ME Firmware Cleaning Guide
                    • mferna14
                      • Jun 2018
                      • 1018
                      Good morning @hardware1., wishing you a good day. I think the BIN files which you send is working as the status of AMP meter now changed to 20v taken from the AC Power adapter, yet it still does not turn on. There is a problem with the motherboard too which I have to troubleshoot. Anyway thanks for all the help. have yourself a great eveing.
                      • hardware1
                        • Sep 2021
                        • 2930
                        • N/A
                        #51
                        Good news, you're welcome.
                        • iori1881
                          • Sep 2023
                          • 54
                          • United Kingdom
                          #52
                          Help please
                          • MuertoGB
                            • Sep 2021
                            • 94
                            • United Kingdom
                            #53
                            Originally posted by iori1881
                            Help please
                            You have only dumped 64Kb of the firmware, please dump and upload the entire firmware. The full dump should be 8,388,608 bytes.
                            • iori1881
                              • Sep 2023
                              • 54
                              • United Kingdom
                              #54
                              How? This only what i got
                              • MuertoGB
                                • Sep 2021
                                • 94
                                • United Kingdom
                                #55
                                Check your settings and selected IC in the programmer software.
                                • iori1881
                                  • Sep 2023
                                  • 54
                                  • United Kingdom
                                  #56
                                  I think i did mistake and erased the chip
                                  • MuertoGB
                                    • Sep 2021
                                    • 94
                                    • United Kingdom
                                    #57
                                    If this is the case, you will need a donor firmware built with your serial number, clean Managamenet Engine and clean NVRAM stores. Send your SN and I can do this for you.
                                      • 20795
                                      Help please
                                      You MUST:
                                      • iori1881
                                        • Sep 2023
                                        • 54
                                        • United Kingdom
                                        #59
                                        SERIAL NUMBER : CO2TC28GGTDX ,model : A1706 , board number : 820-00923-A
                                        THANK YOU VERY MUCH
                                        • MuertoGB
                                          • Sep 2021
                                          • 94
                                          • United Kingdom
                                          #60
                                          THANK YOU VERY MUCH
                                          Try the attached file and write back.
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • capon5153
                                            Macbook A1706 works perfectly but no data on USB C
                                            by capon5153
                                            hello,
                                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                            06-22-2025, 09:42 AM
                                          • B2L_Repairs
                                            Macbook A1706 touchpad and keyboard not working. Please help
                                            by B2L_Repairs
                                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                            10-09-2023, 04:56 AM
                                          • obelix24
                                            A1706 - Macbook pro - one USB-C port only 20V 0A
                                            by obelix24
                                            I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                            I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                            There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                            There were some broken pads under CD3215 but i've recreated them.
                                            What should be...
                                            05-22-2024, 08:04 AM
                                          • zakeric
                                            Need macbook A1706 3163 bios dump
                                            by zakeric
                                            dump original...
                                            09-13-2021, 04:26 AM
