Macbook Pro A1706 EMC 3163 820-00923-A pass pleas
  • iori1881
    • Sep 2023
    • 54
    #61
    Re: Macbook Pro A1706 EMC 3163 820-00923-A pass pleas
    Originally posted by MuertoGB
    Try the attached file and write back.
    you're a champion ... works well ...thank you very much
    i've same issue with another board a1708 ,serial number :*********************************** ,BOARD NUMBER : 820-00840-A
    THANK YOU AGAIN
      • 21679
      THANK YOU AGAIN
      Different model,post your request in one of the a1708 threads.Use the forum search to find the threads.
      • danfernando
        • Jan 2022
        • US
        #63
        SERIAL NUMBER : CO2SWBJ2HF1R ,model : A1706 , board number : 820-00923-A
        The Macbook is asking 6 digit PIN code and I'm wondering if it can be removed. I have the original BIOS file. Thank you in advance!
        • MuertoGB
          • Sep 2021
          • 94
          #64
          @danfernando
          There was 200h of uncessary 0xFF padding on the end of your file, I have removed it.
          Message Authentication Code invalidated and VSS NVRAM cleared, try the attached file and write back.
          • peste
            • 13430
            • ROMANIA
            #65
            @danfernando
            try..
            • danfernando
              • Jan 2022
              • US
              #66
              Originally posted by peste
              try..
              It works! THANK YOU!
              • MuertoGB
                • Sep 2021
                • 94
                #67
                @peste
                You have posted an identical firmware back to me that I already unlocked for someone else. I don't understand why you have done this.
                @danfernando
                Those thanks were for me, and no worries at all.
                • peste
                  • 13430
                  • ROMANIA
                  #68
                  @peste
                  @danfernando
                  By mistake I posted the unlocked bios to you... of course the "laurels" are yours... now, I hope you understand what happened...
                  • HassanMahainiy
                    • Jan 2024
                    #69
                    Hello I need help please thank you in advance
                    I received a "MacBook Model A1706 " device because it is locked with a passcode and also through recovery mode there is a "EFI" lock.
                    I forgot to backup the original BIOS file and wrote a file from the Internet.
                    Now I am facing a problem. In the device disk utility recovery mode, the storage capacity shows only 1 GB and there is no other information or another Partition.
                    I tried to write several other Bios files and the same thing, there is nothing new, the problem is still the same and it is only 1 GB memory.
                    I need a file compatible with my device and the serial number that will solve the problem, or if my problem is not the BIOS file in this case, are there any tips and recommendations to solve this problem?
                    Below you will find all the information about the device, the device model, and also a serial number
                    I appreciate your help. Best regards
                    MacBook Model A1706 EMC 3163
                    Serial: C02VH6N8HV2L
                    Board ID: 820-00923-A​
                    • badu1210
                      b? dư
                      • Oct 2016
                      • 6
                      • VIỆT NAM
                      #70
                      Can anyone help remove the password on this? . Thank you in advance!
                    • lavie
                      • Aug 2015
                      • 90
                      • southafrica
                      #71
                      greetings please unlock A1706-EMC 3163
                      S/N C02W26HZHV2L
                      • danito
                        • Jun 2016
                        • 1068
                        #72
                        S/N C02W26HZHV2L
                        Try
                        • mike66460
                          • 8
                          Hello everyone.
                          I would really appreciate if someone Could help me with the bios.
                          Previously the system would require a six digit pass code.
                          I managed to edit the $SVS hex lines with no luck.
                          Currently the system after editing sees the boot disk but after trying to boot it goes and asks for a pin number.
                          Macbook A1706 EMC 3163
                          Serial number C02V37G9HV2L
                          Firmware EFI
                          The original Bios dump is as attached​
                          • Blaze Tech
                            Learner
                            • 214
                            • Ghana
                            #74
                            Originally posted by mike66460
                            Hello everyone.
                            Firmware EFI
                            TRY
                              • 21679
                              Hello everyone.
                              Firmware EFI
                              Thread merged.
                              Read https://www.badcaps.net/forum/troubl...23#post1622423
                              Quote: If there is an iCloud pin, you need to perform 3x PRAM reset after removing password. If FindMyMac is still enabled, you have to reinstall macOS while being disconnected from the Internet, then reconnect after logging in and bind to a new Apple account.
                              • lavie
                                • Aug 2015
                                • 90
                                • southafrica
                                #76
                                Originally posted by danito
                                Try
                                Thanks boss working perfect
                                • simo
                                  • 27
                                  Mackbook Pro A1706
                                  820-00923-A need Clean ME
                                  serial Number : C02WQ1NNHV2L
                                  Emc 3163
                                  if anyone can help to Clean Me this original dump here ,
                                  machine came in not turning on, when i flashed the the one i cleaned ,
                                  the fan start fast and keep spining fast no post on lcd.
                                  thanks in advance​
                                  • shiyab
                                    • Sep 2023
                                    • 1592
                                    • india
                                    #78
                                    Originally posted by simo
                                    Mackbook Pro A1706
                                    Emc 3163
                                    thanks in advance​
                                    hi try
                                    • awad Hamdan
                                      • Nov 2024
                                      • Lebanon
                                      #79
                                      Please help apple macbook pro A1706 EMC 3163 EFI lock
                                      • shiyab
                                        • Sep 2023
                                        • 1592
                                        • india
                                        #80
                                        POST backup bios
                                        • Danielreinaa
                                          HELP need password bios Macbook A1706
                                          by Danielreinaa
                                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                          09-07-2024, 03:47 PM
                                        • capon5153
                                          Macbook A1706 works perfectly but no data on USB C
                                          by capon5153
                                          hello,
                                          so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                          i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                          06-22-2025, 09:42 AM
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • obelix24
                                          A1706 - Macbook pro - one USB-C port only 20V 0A
                                          by obelix24
                                          I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                          I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                          There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                          There were some broken pads under CD3215 but i've recreated them.
                                          What should be...
                                          05-22-2024, 08:04 AM
                                        • zakeric
                                          Need macbook A1706 3163 bios dump
                                          by zakeric
                                          dump original...
                                          09-13-2021, 04:26 AM
