Dell G3 15 3500 bios help
hi friends
lap top Dell G3 15 3500 selek g3 mlk n18p 19795-1
windows make update for bios but lap top shutt down
after that no screen
please clean me my file
my service tag is
H28D63
Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
Service Tag: DH28D63Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hello everyone. I have a Dell G3 15 3500 selek g3 mlk n18p 19795-1 laptop. When updating the bios, the computer turns off and turns on without showing the screen. I read the 8M chip and it reads normally, but the 16M chip shows an error. Please help me.
ST: J39X563Attached Filesif you find these attachements useful please consider making a small donation to the site
remove the chip from the motherboard before writing or reading...if you don't have a hook, solder wires between the chip and the programmer...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Good afternoon, could any expert help me repair the BIOS on this Dell laptop? I've tried several BIOSes from this forum, and they all give different symptoms. Some turn on and off every 5 seconds, others have the fans spinning at full speed, and so on. Unfortunately, the serial number and service tag were erased from the label.
Dell G3
PCB SELEC G3 MLK N18P 19795-1 403YF $LAAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500Good afternoon, could any expert help me repair the BIOS on this Dell laptop? I've tried several BIOSes from this forum, and they all give different symptoms. Some turn on and off every 5 seconds, others have the fans spinning at full speed, and so on. Unfortunately, the serial number and service tag were erased from the label.
Dell G3
NEED HELP , THE LAPTOP TURN ON WITH RGB COLOR BUT NO BOOT NO DISPLAY
SELEK MLK N18E
19753-1
FJT96$KA
DON'T HAVE S/TAttached Filesif you find these attachements useful please consider making a small donation to the site
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi
Hello. I added the service tag yes. But the following is happening, when I restart or turn it off and on again, it doesn't show video. 2 orange and 7 white flashes (LCD display). But I already got a new screen and it's still the same thing. To show video again, just reset the bios or force it to turn on and off about 5 or 7 times until it shows video. But if you turn it off or restart it, it has no image and the LEDs blink like I said.
Can you tell me what it could be?
Did you manage to solve it
I have the same issue
ThanksComment
hello i have corrupt bios can someone help me its a dell g3 15 p89f002 service tag 3RCHG63 i give the dump of the two chip, thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell G3 15 3500
Service tag 3RCHG63Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I have a a dell G3 15 3500 that do not boot anymore since bios update: I have 3 amber blink then 1 white. I already changed CMOS battery by a new one with no success.
This is the dump of my two bios image file dump.rar
Could you help me to fix my bios ?
REG Model P89F002,
Service tag B3RK303Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi !
Only blinking LEDs .
Service tag : HCDSF63
Thanks !Attached Filesif you find these attachements useful please consider making a small donation to the site
hi all
can help me with this bios I tried more than one from topic it open but cant save service tag
upload old bios
service tag :1CG71B3
MOTHERBOARD 19795-1Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by evolpeHi guys, can anyone help me with this bios? It needs to be cleaned.
Motheboard: GDI5A LA-K033P REV 1.0 (A00)
Service TAG: BNV5GD3
I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
