THINKPAD L390 password
  • Linux200
    • Sep 2020
    • 12
    • Algeria
    Re: Need help bios L390 1.36 computrace activated
    Originally posted by hoaca388
    Hi , thank you for your response
    i flashed the file with rt809 same probleme (blackscrenn with beep) :-(
    • onizzbox
      Banned
      • Nov 2018
      • 604
      • Brazil
      @Linux200
      If you intend to test everything that will be posted here, remember that an eprom supports up to 100,000 thousand recordings only.
      Please wait... I have already received your help request.
      • onizzbox
        Banned
        • Nov 2018
        • 604
        • Brazil
        Hi , thanks for reply same probleme with this file posted above black screen and bip (tpm initialization 0285) with and without a locked hard drive inside :-(
        @Linux200
        Post a picture of cover, I need the full model of the laptop.
        Via patch only these models:
        ThinkPad L390 (20NR, 20NS)
        ThinkPad L390 Yoga (20NT, 20NU)
        • Linux200
          • Sep 2020
          • 12
          • Algeria
          Originally posted by onizzbox
          @linux200
          post a picture of cover, i need the full model of the laptop.
          Thinkpad l390 (20nr, 20ns)
          thinkpad l390 yoga (20nt, 20nu)
          20nus2w700 latest bios version 1.36
          i can reach windows
          • nassih
            • Oct 2015
            • 276
            • morocco
            need bios dump lenovo l390
            hello everyone! I have this laptop that won't turn on, when I plug in the charger I just see the power button LED flashing 3 times, the history of this laptop it had the bios password, I removed the bios chip to get the dump but my programmer stopped working, I put the bios chip back and I got this error, if possible a dump for this motherboard model : lkl-2 mb 18724-1 448 0fc03
            tanks
              • 20674
              Re: need bios dump lenovo l390
              tanks
              Its important to make a good backup. Make another two backups,compare them with a hex editor or some other file compare software to make sure both are the same,then post one of your backups. Not sure if the password can be removed though on this model by patching,you might have to use JTAG
              • nassih
                • Oct 2015
                • 276
                • morocco
                #27
                Re: THINKPAD L390 password
                OK,i have replaced bios chip and put my dump,now laptop turn one but i have password on bios configuration i can't change setting boot to uefi
                • nassih
                  • Oct 2015
                  • 276
                  • morocco
                  #28
                  this
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    #29
                    Try
                    • zak53
                      • May 2018
                      • 18
                      • Z
                      #30
                      Hello guys, i patched the bios dump, but no success melody with black screen can someone please help me
                      • onizzbox
                        Banned
                        • Nov 2018
                        • 604
                        • Brazil
                        #31
                        What would be the laptop's initial problem, BIOS password?
                        • zak53
                          • May 2018
                          • 18
                          • Z
                          #32
                          yes sir the password, the type: 20NU-S0Y400
                          • onizzbox
                            Banned
                            • Nov 2018
                            • 604
                            • Brazil
                            #33
                            Post the BIOS with 32Mb
                            • zak53
                              • May 2018
                              • 18
                              • Z
                              #34
                              @zak53
                              Yes, it is possible to unlock it using my Autopatch. Post the BIOS with 32Mb
                              there is two chips BIOS 1 W25Q128JV, and BIOS 2 25q80dvsig
                              here is the dump of the BIOS 1 W25Q128JV
                              • Bsolution
                                Banned
                                • Oct 2021
                                • 73
                                • punjab
                                #35
                                STEP 1: Flash and replace current BIOS with the generated patch file
                                STEP 2: Boot the machine
                                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                STEP 4: Enter any character when asked for Supervisor Password
                                STEP 5: Press enter when it shows Hardware ID
                                STEP 6: Press space bar 2x when asked
                                STEP 7: Turn off machine
                                STEP 8: Restore original BIOS
                                STEP 9: Reset BIOS settings to factory defaulT
                                • zak53
                                  • May 2018
                                  • 18
                                  • Z
                                  #36
                                  i flashed the chip, but when i compare the patched dump with the programmed one it's not the same there is a deleted part as you can see in the screenshot
                                  I removed the chip from the mother board and i use XGPRO TL866ll PLUS
                                  • Bsolution
                                    Banned
                                    • Oct 2021
                                    • 73
                                    • punjab
                                    #37
                                    this is patched
                                    • zak53
                                      • May 2018
                                      • 18
                                      • Z
                                      #38
                                      this is patched
                                      Yes, i don't know why the file is not the same after the flash
                                      • zak53
                                        • May 2018
                                        • 18
                                        • Z
                                        #39
                                        I managed to flash the patched dump with a good compare, but still the same melody with black screen
                                        When i put back the original dump the laptop work fine, but with password
                                        • dycc
                                          Vision
                                          • Nov 2011
                                          • 625
                                          • Côte d'Ivoire
                                          #40
                                          Try
                                          • Maxpower3
                                            Brand name and Model Type for Lenovo error 2202 product name is invalid
                                            by Maxpower3
                                            Info for error 2202 LenovoThinkPad models and type
                                            Extract from ThinkPad Maintenance Utilities Configuration File
                                            plnsrv.ini Version 1.01
                                            Some information that may be useful
                                            There must also be missing models, add them to the list if you know of any.
                                            Code:
                                            brand name
                                            20B1=ThinkPad Edge E445
                                            20B2=ThinkPad Edge E545
                                            20BC=ThinkPad Edge E145
                                            20BM=ThinkPad X140e
                                            20BL=ThinkPad X140e
                                            20A3=ThinkPad X230s
                                            20AH=ThinkPad X230s
                                            20AK=ThinkPad X240s
                                            20AJ=ThinkPad X240s
                                            02-21-2024, 10:27 AM
                                          • samirinfo
                                            THINKPAD T450 password autopatcher not succees
                                            by samirinfo
                                            hello .
                                            i have THINKPAD -T450 with password
                                            i tried autopatcher . BUT NOT WORK I HAVE BIOS ORIG BACK UP
                                            PLZ HELP....
                                            03-08-2023, 04:43 AM
                                          • RAR1991
                                            THINKPAD L390 Not turning on after password remove
                                            by RAR1991
                                            Hi, I've tried to unlock a ThinkPad L390 and used a patched file meant for another laptop but after putting back th e original dump the laptop refuses to power on. if there is anyone that has a solution I will be be very grateful.
                                            12-03-2022, 04:26 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                            Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E14 Gen 2 (Intel) boardview and ThinkPad E14 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:20 AM
