Hi, I've tried to unlock a ThinkPad L390 and used a patched file meant for another laptop but after putting back th e original dump the laptop refuses to power on. if there is anyone that has a solution I will be be very grateful.
THINKPAD L390 Not turning on after password remove
Re: THINKPAD L390 Not turning on after password remove
Hi.
1) link a schematic or more details on the silk screen markings on the logic board.
2) Is the power adapter the typical barrel / coax round connector? Check the voltage to ground at the dcin connector. Check the same at every large coil. If you see a very low voltage then the power path has to be reviewed.
Which charger IC is on this logic board? This part should be near the 2 x DCin mosfets close to where the dcin connector is located. The charger IC is often the 'BQ' series from Texas Instruments.
Update: it is a usb c power delivery adapter. Check the voltage to ground on each grey coil to get started.Last edited by mon2; 12-03-2022, 05:23 AM. -
Thanks for the reply the Laptop is a ThinkPad L390_TYPE 20NU-S0Y400
MB Model : LKL-2 MB 18724-1M schematics attached. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...ga#post1562873
want just to precise that the laptop was working before the bios password remove attemptComment
for unlocking there is custom bios that can edit fw in T2 ic or other where is password stored. so u probably mess this fw.Comment
Clean the ME firmware of the original bios backup,flash it back.Did you remove all batteries, is there a tamper switch on this modelComment
by luanthanhHELLO EVERYONE, CAN SOMEONE HELP ME REMOVE THE BIOS PASSWORD ON A LENOVO THINKPAD E14 GEN 2
I USED THE CH341A TOOL TO EXTRACT THE BIOS FILE WITH A SIZE OF 32768 Kb
Model: 20TA-001LJP
S/N: PF-39AYGW
P/N: SL11B03769
Motherboard number: 8SSB20W48312L1HF1A803BB
I WOULD BE VERY GRATEFUL IF SOMEONE COULD HELP ME....-
Channel: BIOS Requests ONLY!
by m.sabry2110Lenovo ThinkPad t550 bios password remove
type 20cj-s14p0c...-
Hi
LENOVO ThinkPad E14 E15 JE442 NM-E211 bios supervisor password remove...-
by RMDUiFTGood day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
I have a few questions:- If I would buy this laptop and have
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
- Loading...
