lenovo Flex 5 bios need
clean me region latest tryAttached FilesLeave a comment:
please try and give feedback WIN+SERIAL = UPDATE BIOSAttached FilesLeave a comment:
​Leave a comment:
Hi everyone
Can someone help me fix bios
No image and no post after bios update TO FXCN48WW.CAP
LENOVO IDEAPAD FLEX 5 15itl05 sn: R9119MNX
LC56 - 14T
203044 - 1
THANKSAttached FilesLast edited by dima329; 08-05-2024, 01:22 AM.Leave a comment:
Hello seniors, please help, the Lenovo laptop has no screen display after updating Windows, when I wanted to retrieve the bios file I found damage to the bios IC, I tried flashing the bios From the files in this forum, it displays successfully, but after I turn off the laptop and turn it on, there is no display anymore.
Please repair this file
LENOVO IDEAPAD FLEX5 14ARE05
Kode board LC55-14A 19793-1M
448.OK103.001M
SN R90ZR6WK
TYPE 81X200EGID
​Leave a comment:
448.OK103.001M
SN R90ZR6WK
TYPE 81X200EGIDAttached FilesLeave a comment:
Re: lenovo Flex 5 bios need
Hi, can anybody repair my not working bios?
Model : 81X2
Serial : R911K97P
many thanks flueppAttached FilesLeave a comment:
if it doesn't work, either you wrote the bios with errors or the laptop has another problem.. use the HxD program to transfer the DMI information from one bios to another.. enter both bios into the program and then (copy-paste) from one bios to the other.. the interval ( DMI) which must be copied, you can find it at item #51..Leave a comment:
Hi Peste,
used the bios in post 3 however same result. Can the DMI information, windows key and serial number be transferred to the new bios if possible. thanks againLast edited by ub6ib969; 08-03-2023, 10:44 AM.Leave a comment:
DMI B21000 - B213FFLeave a comment:
Hi Everyone,
Unit powers on however blinking power light and caps lck and esc key lit. Request help in with clean bios.
Lenovo Flex 5
p/n: LC55-14A
19793-3
BIOS: GD25LQ128C
Thanks in advance.Attached FilesLast edited by ub6ib969; 08-02-2023, 04:58 PM.Leave a comment:
Hi Everyone,
I have the Flex 5 -14ARE05, Esc and Caps Lock lights are on, black screen, fans kick in when required and the laptop charges.. From what I have read on here these seem to be the same symptoms that others on here are getting therefore re flashing their bios to cure the problem.
I have tried flashing my bios and a number of bios's from this thread only to end up with exactly the same symptoms, nothing changes no matter which bios I flash. I am using the CH431A V1.7 which allows me to select 1.8v without an adapter. This I have also confirmed with a multimeter. My bios chip is a MX25U12873F and my logic board is a LC55-14A.
Can anybody help me with this issue?
Many thanks
https://www.badcaps.net/forum/forumdisplay.php?f=23
.Leave a comment:
Hi Everyone,
Many thanksLeave a comment:
by claws77my laptop is lenovo flex 5 14ITL05
recently my power supply for this laptop developed a fault.
which caused a short in my usb c port -- verified with a new charger.
rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32... -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by SMDFleaThese models use the same bios: Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019
Backup bios used for this tutorial https://www.badcaps.net/forum/showthread.php?t=97978 Post #13
Extract & Edit.
Download the lenovo update from - https://download.lenovo.com/consumer...s/crcn17ww.exe
Extract the first exe using innoextract - https://constexpr.org/innoextract/#download
Extract the second exe using 7-zip or winrar - https://www.7-zip.org/download.html
- Loading...
