lenovo Flex 5 bios need
Hi everyone!!
Could you please help me fixing this BIOS? Thanks in advance
Lenovo Ideapad Flex 5-14ITL05 Laptop - Type 82HS
S/N: R912W5LD
BIOS VERSION: FXCN49WW
Issue: after a bad upgrade laptop won`t recognize SSD NVMe, other than that everything is ok.
Thank you very muchAttached FilesLeave a comment:
hello you found a solution I have the same problem as you on the same computer and the same motherboard thank you.Leave a comment:
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on. -
BONJOUR
no display issue
LC55-14A
19793-3
448.0K104.0031Attached FilesLeave a comment:
Hi Everyone,
Laptop powers on however blinking power light and caps lock and esc key lit.
Can any one help in with clean bios?
Lenovo Flex 5-14ARE05 Laptop (ideapad flex) - Type 81X2
LC55 - 14A
19793 - 1M
BIOS IC: GD 25LB128DSIG
s/n: R913SF1YAttached FilesLeave a comment:
Hi Everyone,
Lenovo Flex 5-14IIL05 Laptop (ideapad) - Type 81X1
BIOS IC: 25Q128JVSQ
s/n: R90ZTCPXAttached FilesLast edited by koby058; 09-08-2024, 03:30 PM.Leave a comment:
It’s happened after bios update
After the whole process, the computer wrote that everything was completed successfully and after that was reset and after that black screen and caps lock
I think it biosLeave a comment:
by claws77my laptop is lenovo flex 5 14ITL05
recently my power supply for this laptop developed a fault.
which caused a short in my usb c port -- verified with a new charger.
rant: so, i went to the repair tech in my country, he asked for a huge repair cost when i decided to get it done someplace else this "great person" nicked my bios chip, asked me to be aware for repair scams lol.
I was stupid and unable to find the flaw at the moment. Another repair tech told me that my bios chip was stolen and an 8mb bios chip is in place of that. he told me that a 32... -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by SMDFleaThese models use the same bios: Lenovo IdeaPad C340-15IML/FLEX-15IML/S340-15IML/S340-15IML Touch/S340-14IML Lenovo XiaoXin-15IML 2019/XiaoXin-14IML 2019
Backup bios used for this tutorial https://www.badcaps.net/forum/showthread.php?t=97978 Post #13
Extract & Edit.
Download the lenovo update from - https://download.lenovo.com/consumer...s/crcn17ww.exe
Extract the first exe using innoextract - https://constexpr.org/innoextract/#download
Extract the second exe using 7-zip or winrar - https://www.7-zip.org/download.html
- Loading...
