Need unlock HP elitebook 830 G6
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #81
    Re: HP BIOS unlock tool
    Originally posted by onelook
    could someone please unlock this BIOS
    HP 830 G6
    Thank you
    Here you are
    Become a Badcaps supporter
    Thanks to all supporters.​
    • onelook
      • May 2020
      • 27
      Originally posted by Vesko356
      Here you are
      Thanks bro
      It worked perfectly
      • marpoo
        • Nov 2021
        Re: Need unlock HP elitebook 830 G6
        I've opened this 830 G6 up and for the life of me, I can't find the chip! Can someone give me a heads up whereabouts on the board the chip I want to be reading is? The pic below is the only chip I can find. It's located next to the DIMM2 slot. I'm pretty sure this is not the one I need to be looking at, but is the size of chip I need to be searching for?
        Apologies in advance for my lack of knowledge.
        Marpoo
        • peste
          • Dec 2016
          • 13865
          • ROMANIA
          #84
          Marpoo
          maybe it's on the other side of the motherboard ...
          • marpoo
            • Nov 2021
            I had not considered that! Are they not all standard in their construction? e.i. would all 830's not be made the same ?
            • stevie
              • Apr 2010
              • 30
              #86
              have a recycled EliteBook 830 G6 could member please help unlock
              thank you
              • Bsolution
                Banned
                • Oct 2021
                • 73
                • punjab
                #87
                Originally posted by stevie
                have a recycled elitebook 830 g6 could member please help unlock
                thank you
                reprogram only 16mb
                • corona100
                  • Mar 2020
                  • 155
                  • U.S.A
                  #88
                  hello guys i have password in this Hp 830 G6
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #89
                    Upload your 16MB bios dump.
                    • rkumar99
                      • Aug 2018
                      • 5
                      • India
                      #90
                      Originally posted by shabi
                      reprogram only 16mb bios and enjoy
                      HI bro can you teach me bios editing and bios password remove
                      • mepttbblk
                        • Jan 2022
                        • 37
                        • Ukraine
                        #91
                        Hello, there are two HP 830 g6 laptops, on one it was possible to remove the password using RCU, and the second one does not turn on with a patched dump. Tried HP unloker too without results.
                        Thanks in advance for your help.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #92
                          Originally posted by mepttbblk
                          ...does not turn on with a patched dump...
                          It is obvious why this happens.
                          Just compare the files and you'll find out.
                          • mepttbblk
                            • Jan 2022
                            • 37
                            • Ukraine
                            #93
                            Hello, after editing the dump, the password is no more. But when starting the laptop, it gives an error. Resetting BIOS settings and updating did not help. Help to remove the error please.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #94
                              hello, after editing the dump, the password is no more. But when starting the laptop, it gives an error. Resetting bios settings and updating did not help. Help to remove the error please.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12426
                                #95
                                RC-unkocker.
                                ​https://www.badcaps.net/donate
                                • mepttbblk
                                  • Jan 2022
                                  • 37
                                  • Ukraine
                                  #96
                                  Thank you, works perfect. Now will try dell, my old cha341 programmer refused to write flash drives, a new one writes, can you advise which programmer to buy?
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #97
                                    1.1.1. Programmers
                                    TL866II is arguably the most reliable and easy to use programmer while still being relatively cheap.
                                    If you also need eMMC support, consider T56 or RT809H
                                    If you need LCD monitor In-System Programming through VGA port, consider RT809F or RT809H.
                                    1.1.1.1. TL866II
                                    Supports I2C, SPI, LPC, FWH, parallel.
                                    Support list: http://www.autoelectric.cn/MiniPro/TL866II_List.txt
                                    1.1.1.2. T56
                                    Supports I2C, SPI, LPC, FWH, parallel, eMMC.
                                    Support list: http://www.xgecu.com/MiniPro/T56_List.txt
                                    1.1.1.3. RT809F
                                    Supports I2C, SPI, LPC, FWH, VGA ISP.
                                    Parallel interfaces support requires PEB-1 extension board and can be troublesome.
                                    Support list: https://www.hklrf.com/24download/img/RT809F-List6.txt
                                    Software: http://doc.ifix.net.cn/download/2017266
                                    1.1.1.4. RT809H
                                    Supports I2C, SPI, LPC, FWH, parallel, eMMC, VGA ISP.
                                    Support list: https://hklrf.com/24download/img/RT809H-List8.txt
                                    1.1.1.5. EZP2019
                                    Supports I2C (24-series), SPI (25-series), 93-series.
                                    Support list: https://www.hklrf.com/24download/img/EZP2019-List.txt
                                    https://www.badcaps.net/forum/showpo...40&postcount=2
                                    • aalyatim
                                      • Mar 2022
                                      • 18
                                      • usa
                                      #98
                                      Can someone help me unlock the hp elitebook 840 g6 password?
                                      I tried HP unlocker it didn't remove the password. I looked for another chip but I couldn't find any besides those 2.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #99
                                        There's another 16MB chip, find it.
                                        • aalyatim
                                          • Mar 2022
                                          • 18
                                          • usa
                                          #100
                                          Would it be on the back side of the computer? I only looked on the front and couldn't find it.
