Re: ME Firmware Cleaning Guide
Me region or Me subpation
Hi
I am trying to clean a Razer Blade 15 BIOS.
But I cant find ME Region.bin in the fit Dump folder.
Any idea what I am doing wrong??
CheersLeave a comment:
I would go for the lowest one, has cor_lp_c_npdm, look at the chipset on MEI. The highlighted one has cor_lp_hd. Would someone more experience corroborate?Leave a comment:
Thank You Hoaca,
this version works without errorLeave a comment:
Attached FilesLast edited by SMDFlea; 05-30-2022, 09:10 AM.Leave a comment:
I am trying to clean me with fit version 15.
but i get error
Intel (R) Flash Image Tool. Version: 15.0.35.1951
Copyright (c) 2013 - 2021, Intel Corporation. All rights reserved.
5/30/2022 - 12:18:12
Using vsccommn.bin with timestamp 15:10:12 08/11/2021 GMT
Command Line: C:\Users\Gebruiker\Desktop\intel me\csme system tools\CSME System Tools v15.0 r14\Flash Image Tool\WIN32\fit.exe
Log file written to fit.log
Loading C:\Users\Gebruiker\Desktop\intel me\csme system tools\CSME System Tools v15.0 r14\Flash Image Tool\WIN32\dell 3420.bin
Decomposed SKU Value: "Intel(R) Tigerlake LP B0 Chipset - TGP-LP-B0 No Emulation".
FIT version used to build the image: 15.0.30.1776
Error 179: [Fit Actions] Failed to parse CSE region.
Error 10: [Ifwi Actions] Failed to decompose Region. Failed to decompose CSE data.
Error 18: [Ifwi Actions] Failed to generate decomposed files. CSE Region
Error 9: Failed to decompose Image.
Unable to open file: C:\Users\Gebruiker\Desktop\intel me\csme system tools\CSME System Tools v15.0 r14\Flash Image Tool\WIN32\dell 3420.bin. Reverting to default configuration.
Loading defaults.
someone can help me with this problem?Leave a comment:
I will search similar posts or make a new one and upload my bios tommorow.Leave a comment:
Ive never seen that error before. Post your backup in another thread, if theres one with the same laptop/motherboard model as yours, or start a new thread please,and we`ll see whats wrongLeave a comment:
The key is not in the ME region,it is in the bios region,which you have flashed with a clean one,thats why you have lost the key - https://www.badcaps.net/forum/showpo...15&postcount=9Leave a comment:
Hp Zbook 17 G4 - CPW70 LA-E171P
Need help to restore MS UEFI KEY (MSDM)
After Cleaning ME - the key was lost. Is it possible to insert MS key to new ME region?
Thanks!Leave a comment:
Linux defaults to PS2 emulation if the HID/I2C/Smbus protocols are not found. So what you are seeing is basic PS2 emulation of the touchpad under Linux. That means the necessary HID device structures have not been integrated into the firmware when you modified the firmware.Leave a comment:
It means part of the ME FW is corrupt.If the bios opens and builds ok with FIT its fixed but sometimes it can be too corrupt and it won`t open.Leave a comment:
Hello SMDFlea
I have a question in the picture if I had this error in the ME Analyzer again when checking the BIOS file.
What does it mean now?
Error: MFS Data Page 402 > Chuck 1020 CRL-16 is INVALID !
Maybe you can explain that to me.
Thanks in advance.Leave a comment:
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
