ME Firmware Cleaning Guide
  • volinakis
    • Jan 2021
    • 2805
    • N/A
    #221
    Originally posted by bondminer009
    yes, all you're described is good enough and can understand it. after got the FWUpdate.bin, MEA can check the file but once put back into FIT got issue CSE region issue.
    in my case : ME 16.1.30.2330 and FIT 16.0.15.1545
    and try to edit using HXD also didnt work.
    Need guidance please , thank you
    well, you said " once want to check MEA , freeze, not appear (Blank)" , so I thought that's the problem. Use MFIT 16.1 it's obvious you are using wrong MFIT (16.0)
    • bondminer009
      • Nov 2023
      • 48
      • Malaysia
      #222
      my mistaken, this case happened with my post about precision 5570, freeze cant check through MEA.
      All was clear here, thank you so much
      • MAREBELE
        • Jan 2023
        • 41
        • Indonesia
        #223
        I was struggling to find on internet ME Fw 16.1 27.2225 Corporate LP ADP A for HP 640 G10 and I had the idea to use MFIT 16.1 to extract ME Firmware from update package and ... it works!
        What I did:
        1. Downloaded bios update from HP that corresponds with my bios version (V75 01.02.03)
        2. unpack bios update and there is a bin file , in my case V75_01020300.bin
        3. Decompose V75_01020300.bin with MFIT 16.1
        4. Hit "Build" tab. MFIT will create image "FWUpdate.bin"
        Click image for larger version  Name:	IMG_1151.jpg Views:	361 Size:	4.11 MB ID:	3463742
        Click image for larger version  Name:	IMG_1152.jpg Views:	305 Size:	4.00 MB ID:	3463743
        Click image for larger version  Name:	IMG_1153.jpg Views:	306 Size:	6.63 MB ID:	3463744
        Click image for larger version  Name:	IMG_1154.jpg Views:	305 Size:	2.71 MB ID:	3463745
        iam new at bios, ive got the FWupdate form extacted bios how can i put it back to my dump bios?. because i have no clue how to do it
        • volinakis
          • Jan 2021
          • 2805
          • N/A
          #224
          With MFIT but this time you decompose your bios backup, save it, replace ME Subpartition with extracted ME Fw from update, upload saved .xml file and hit "Build" tab. Read this thread from the beginning, it's very useful.
          • MAREBELE
            • Jan 2023
            • 41
            • Indonesia
            #225
            Is there a way to manualy or other way to edit the me without using MFIT to rebuildthe image?, my prosecor is from meteor lake which i think not yet supported by csme 16.1,
            ive also attach the bios dump and extracted bios from dell
            • volinakis
              • Jan 2021
              • 2805
              • N/A
              #226
              well, you don't need to use MFIT to extract ME firmware from DELL update package, use DELL_PFS_Extractor and you'll have all modules for bios. You said you attached bios dump but it's nothing to attachements.
              Click image for larger version  Name:	Screen Shot 2024-10-25 at 19.40.03.png Views:	0 Size:	74.4 KB ID:	3492278
              • MAREBELE
                • Jan 2023
                • 41
                • Indonesia
                #227
                it seem when i edit the message the attachment got remove ive attach it again,
                and when i try to write the me to the bios dump using hdx but it gave me eror is there any exra step to take?
                • volinakis
                  • Jan 2021
                  • 2805
                  • N/A
                  #228
                  you CAN'T just replace ME Region with hDx and expect to work, that's why I told you to read guide made by SMDFlea how to clean ME.
                  • MAREBELE
                    • Jan 2023
                    • 41
                    • Indonesia
                    #229
                    Sorry for the misunderstanding, previously is ask,
                    "Is there a way to manualy or other way to edit the me without using MFIT to rebuildthe image?, my prosecor is from meteor lake which i think not yet supported by csme 16.1"
                    I've read the guide by SMDFlea but csme is not yet supported my prosesor generation. If anyone know how to manually rebuild the bios image without Mfit plese let me know
                    • volinakis
                      • Jan 2021
                      • 2805
                      • N/A
                      #230
                      who told you is "meteor lake"? post service tag
Name:	Screen Shot 2024-10-25 at 22.55.32.png
                      • MAREBELE
                        • Jan 2023
                        • 41
                        • Indonesia
                        #231
                        I read the spec wrong, yes it was raptor lake
                        Here the model Inspiron 14 7440 2-in-1
                        ST : 3QRFC24
                        • _Margo_
                          • Sep 2022
                          • 6
                          • Россия
                          #232
                          Hello!
                          I need FIT ver 15.0.30.1776
                          • danito
                            • Jun 2016
                            • 1049
                            #233
                            Originally posted by _Margo_
                            Hello!
                            here
                            • _Margo_
                              • Sep 2022
                              • 6
                              • Россия
                              #234
                              Originally posted by danito
                              here
                              Thanks!
                              • testinglaptops
                                • Oct 2022
                                • 82
                                • United Arab Emirates
                                #235
                                Originally posted by provcoin1999tc
                                How to fix this error cseplugin CLEAR Failed ???????????????????????????
                                Modular Flash Image Tool 16V ERROR
                                I'm facing same problem.
                                Decompose image
                                Decomposing image C:/Users/WorkShop/Desktop/HP WORKSHOP/hp840 g9 br sn.bin ...
                                Exception: Decompose 'C:/Users/WorkShop/Desktop/HP WORKSHOP/hp840 g9 br sn.bin' image failed.
                                Details: 'Error occurred while trying to create container CseRegion. Reason: StorageLib error. Function "meMfsMfitInit" execution failed. Error details: Failed to initialize MFS.'
                                Source: 'CsePlugin'.
                                Senior's any one have solution. Please Help
                                • volinakis
                                  • Jan 2021
                                  • 2805
                                  • N/A
                                  #236
                                  Decompose image
                                  replace Me Region using UEFITool with ME Region extracted from another identical laptop then run MFIT, it worked for me.
                                  • adamgouadma
                                    • Jul 2017
                                    • 195
                                    • setif
                                    #237
                                    Thank you very much, it is very good
                                    • TiagoNecer
                                      • Nov 2022
                                      • 11
                                      • Brasil
                                      #238
                                      It worked, thank you very much!!!
                                      • volinakis
                                        • Jan 2021
                                        • 2805
                                        • N/A
                                        #239
                                        you are welcome
                                        • LBTT1121
                                          • Nov 2024
                                          • 655
                                          • Việt Nam
                                          #240
                                          Hi, I need clearme bios 5310, I have CSE ME 14.1.72.2287 Prod CorpLP CNPCMP-LP B A
                                          but can't find the FIT version to clearme . I have attached the bios file that needs to be cleared.
                                          Can someone provide me with the FIT version to open it?
