Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
  • amperrr
    • Nov 2018
    trying to unlock Surface Pro 5
    Hey guys.
    I'm trying to unlock Surface Pro 5. Got a joblot of 2 of them. Someone already tried unlocking one, and unfortunately touch isn't working. Got it with a 2nd chip, assumed it's original, but nah, modified. Any chance for recovering it? Already installed Windows on it and works fine, except of touch and being unable to install Surface updates manually (windows says incorrect machine and not letting to update), no faults in device manager.
    2nd one, untouched, I'm trying to unlock using your advices. Tried modifying bit at 0x00600045, tried removing all after that, tried too at other point (0x00606... something), to no avail.
    Tested meanwhile what would happen if I'd start it with bios from other one, and started succesfully, but booting like 30s and no touch working, so would like to unlock my original. Can any of you advice me how to find correct password address?
    In attachment my unmodified file for the 2nd one (the one with working touch but password)
    • amperrr
      • Nov 2018
      Re: Surface 4 Pro BIOS locked
      Okay, sorry, found it! Successfully unlocked the 2nd one.
      Now, for the 1st one, any ideas how could I restore touch support and ideally, restore serial number?
      • stevep2k21uk
        • Nov 2021
        • 30
        #63
        Re: Surface Pro 5 bios dump
        Hi
        Is it possible to put a 25q128jvpq bios file onto a 25q128fvpq chip?
        Or are they different
        • stevep2k21uk
          • Nov 2021
          • 30
          #64
          Surface pro 5 1796 256 8gb bios dump
          Hi all
          Does anyone have a bios dump for the surface pro 5(1796) that has version 2.429 touchscreen?
          I can change it to my serial number etc
          Can anyone help?
          • stevep2k21uk
            • Nov 2021
            • 30
            #65
            this is my bios dump
            • hoaca388
              Badcaps
              • Jan 2022
              • 12226
              #66
              Originally posted by stevep2k21uk
              Hi
              Flash chips in VSCC table:
              1F4700 (Atmel AT25DF321)
              EF4018 (Winbond W25Q128)
              • peste
                • 13301
                • ROMANIA
                #67
                try..
                • stevep2k21uk
                  • Nov 2021
                  • 30
                  #68
                  Originally posted by peste
                  try..
                  many thanks,
                  now just need to flash it to to the chip,
                  just a quick question can i do it while the motherboard is still in the tablet or do i need to remove it and all power?
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #69
                    many thanks,
                    For best results (or at least I do it this way) programming of the chip must be done out of the circuit. Otherwise you can expect all kind of problems, in other words don't create yourself a problems out of nothing.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • stevep2k21uk
                      • Nov 2021
                      • 30
                      #70
                      i have tried it both ways but all i get is a flicker of the surface logo the it goes off again,
                      but what i have done is flashed a bios but changed the write proection of the regions to read/write so now i can flash the ME freely using fptw64.
                      which i did and it boots but theres a orange bar at top when it boots,
                      • peste
                        • 13301
                        • ROMANIA
                        #71
                        many thanks,
                        try..
                        • stevep2k21uk
                          • Nov 2021
                          • 30
                          #72
                          try..
                          that seems like a very old version 11.6.20.1221
                          where are the drivers for it?
                          • stevep2k21uk
                            • Nov 2021
                            • 30
                            #73
                            Will it make the touchscreen work though?
                            • stevep2k21uk
                              • Nov 2021
                              • 30
                              #74
                              surface pro 5
                              i have been trying to decode where the password is stored in my bios for surface pro 5
                              i dumped the bios then set a simple "password" then redumped it
                              theres definatley differences between the files,
                              maybe someone can help work out how to decode it, im sure it will help loads of people
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12226
                                #75
                                I'm not a technician but I checked the bios file you posted and found that the "bios region" section is not damaged, it's exactly the same as the firmware downloaded from the Micro Soft homepage. So I would try upgrading your ME firmware one level up. If the problem doesn't solve it, I think it's not bios related.
                                • stevep2k21uk
                                  • Nov 2021
                                  • 30
                                  #76
                                  Re: surface pro 5
                                  further investigations brought me to where the password may be stored.
                                  AWORD in the passworded file appear twice and only once in the unpassworded file - see attached
                                  someone might be able to make a program to decode the password knowing that the password is "password"
                                  i
                                  • stevep2k21uk
                                    • Nov 2021
                                    • 30
                                    #77
                                    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
                                    this is it,
                                    • 69d0b913
                                      • Mar 2018
                                      • 146
                                      • BR
                                      #78
                                      I have a Surface 6 Pro that does not recognize the ssd, it had BitLocker lock, I made a flash with a modified DUMP and was able to access the bios settings, but it no longer recognizes the disk even by CMD commands. Does anyone know about that? Can you help me?
                                        • 21552
                                        This thread is for the Surface Pro 5 .Bump your old thread up https://www.badcaps.net/forum/showthread.php?t=100232
                                        • bafylu
                                          • May 2017
                                          • moldova
                                          #80
                                          hi surface pro 1796 bios password can someone help, thanks
                                          • ArkzG
                                            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                            by ArkzG
                                            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                            What I currently have available:
                                            - Model: FA506NF (2021)
                                            - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                            - Tools: CH341A programmer ready to use
                                            Does anyone have either a clean 2MB .bin dump of this model,...
                                            09-26-2025, 09:34 PM
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
