Dell BIOS Password Hack
  • desone01
    • Sep 2020
    • 14
    From reviewing some of the Forum Threads here I see that quite a few members are having trouble removing passwords from the BIOS.
    I found a program, with instructions, written by a Russian Hacker some years ago. I haven't used the program myself as I haven't needed to use it. I kept the program for possible future use.
    It would appear that some individuals are selling the use of this program on places like eBay. It is highly likely it is the same hack program. The Russian hacker called himself "HPGL". He even supplied the source code for the program. I know NOTHING about compiling programs, however, others here may find a use for the code.
    This program should be used with extreme caution. From the feedback in the Word files, it appears that some individuals have had success with it. It saves having to purchase a new bios chip and soldering it on the motherboard.
    As you can see it's not my work, I simply found it by thorough searching with Google.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Dell BIOS Password Hack
    Nothing new - https://bios-pw.org/
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1375
      • France
      Someone is able to explain the algorithm.
      it would be interesting to understand
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • Sathsul
        Dell Latitude 5431 issues with dumping bios
        by Sathsul
        So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
        The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
        However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
        10-28-2025, 07:49 AM
