T470 bios needed
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #61
    Re: T470 bios needed
    Originally posted by Jetro007
    it was sitting next to the cmos battery, smiling at me
    Become a Badcaps supporter
    Thanks to all supporters.
    • Jetro007
      • Jun 2022
      • 8
      • Belgium
      #62
      Originally posted by Vesko356
      I'm not sure my solder skills are up to it.
      isn't the fact it starts reading a sign the spi communication is ok?
      Can the reason be it hangs, it is corrupt?
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #63
        No, if it was "corrupt", the laptop wouldn't turn on.
        It's just the crappy chinese clip doesn't make a good contact at some of the chip legs, or/and the cable has become unsoldered on one of the pins (the cable is also thin and crappy), that's why.
        Edit; You have to read the chip, then erase it, then program it with the patched dump, then erase it again and program it again with the original dump. I just don't see how it's going to happen with that crappy clip...
        • Jetro007
          • Jun 2022
          • 8
          • Belgium
          #64
          Yeah, i get mixed reactions from different usb ports. Maybe the chip is drawing to much power. got a 90% read one time.
          The laptop doesn't realy turn on.
          The keyboard illumination and power button briefly turn on, then everything shuts down.
          I'll try to desolder it tomorrow.
          If i get succesfull reads, schould i flash the bios posted in the beginning of this thread?
          Thx for the advice so far
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #65
            Oops my mistake - I did not read the whole your first post because of the obviously smaller archive, thought the goal was unlocking but that doesn't change the meaning of what I said, the chip very rarely happens to defect, the much more likely cause of your problems is what I already told you.
            BTW what do you mean by "corrupted in a bad flash" - during the Windows update, or something else?
            • Jetro007
              • Jun 2022
              • 8
              • Belgium
              #66
              yes, during a windows 'system' update.
              when i saw it reboot into a flash, i scrambled for my charger, because i didn't want the battery to die, but i must have bumped it or so.
              It's my old work laptop, but the password was already removed. was running perfectly until the windows update went wrong.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                OK everything is clear, there is no way the chip to get damaged because of this, you just interrupted the update, and it turned out to be the cause of the issue, but that doesn't mean the chip is already defective.
                • gdunk86
                  • Feb 2014
                  • Indonesia
                  #68
                  Hello Everyone,
                  I need BIOS for My Lenovo T470 20JN-S0L303 S/N: PF-151WQL
                  which is IC U49 code WINBOND 25Q128JV
                  and I also need BIOS for for IC U15 code WINBOND 25Q80JV
                  My Lenovo T470 condition now is black screen after softstart, Lenovo Logo doesn't appear after backlight keyboard was dimmed.
                  Thank you
                  • kulokutoys
                    • Jun 2010
                    • 132
                    • Phillippines
                    #69
                    Device: Laptop
                    Brand: lenovo
                    Model: T470
                    S/N: PF-117EK7
                    type 20HE-S18S08
                    Request: Repair
                    boot looping
                    • Salmus666
                      • Jan 2023
                      • 16
                      • Eesti
                      #70
                      Device: Laptop
                      Brand: lenovo
                      Model: T470
                      S/N: PF-0ST5XB
                      type 20HD-0001MX
                      Request: No power on , only charge. Power on with other 20HD bios, but boot loop. Bios corrupted?
                      • kulokutoys
                        • Jun 2010
                        • 132
                        • Phillippines
                        #71
                        up for the request above. thanks
                        • huss584
                          Hussein
                          • Apr 2020
                          • 230
                          • Palestine
                          #72
                          Please need Clean BIOS
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #73
                            Read the rules before posting:
                            You MUST:
                            • huss584
                              Hussein
                              • Apr 2020
                              • 230
                              • Palestine
                              #74
                              I Following the steps step by step but i got this error
                              in these thread https://www.badcaps.net/forum/showthread.php?t=115358
                              The problem is the Charging The “Charge” indication remains on the battery after removing the charger
                              i need help please
                              to clean my BIOS
                              the SN : PC090Q0V
                              the MTM: 20HD000EIV
                              You MUST:
                              • antskull
                                • Aug 2017
                                • 17
                                • jakarta
                                #75
                                Originally posted by hoaca388
                                thanks, work fine on my board CT470 NM-A931 Rev 2.0
                                • essentialphone
                                  • Nov 2023
                                  • UA
                                  #76
                                  Hey friends.
                                  Complete erased my W25Q80JV before tryin to flash one of ur bios
                                  and now get big toruble, all ur bios 16mb, but my chip only 8mb, haha, what i can do now ;0
                                  TYPE 20JN with 6300U
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1355
                                    • France
                                    #77
                                    Originally posted by essentialphone
                                    Hey friends.
                                    https://www.allservice.ro/forum/images/T470_bios.jpg
                                    • ahkh_72
                                      • 110
                                      • Iran
                                      #78
                                      Hey friends.
                                      send your MB model.
                                      .Today should be different from yesterday.
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1355
                                        • France
                                        #79
                                        Hey friends.
                                        here W25Q80BL type 20HE
                                        freshly read
                                        • viorel.m
                                          • Mar 2017
                                          • 7
                                          Originally posted by santi2019
                                          Re: t470 bios corrupted
                                          confirmed bios T470 (Type 20JM, 20JN) Laptop (ThinkPad) - Type 20JN works correctly
                                          It worked on my T470 - Type 20JN
                                          Thank you so much.
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • lofton
                                            Lenovo t470 20jn-sv2vnoe PF1Q63B0 Bios/EC needed
                                            by lofton
                                            Hello, I was flashing the bios but now the machine does not come, the battery indicator turns orange when charge is plugged in. As soon as it plugged by charger or battery the power button and escape blinks once then fade out Sometime it blinks 3 timess . With the back case off i can see the fan spins a little then top, but once i press the button it spins a little then stop and repeat for a while until stops. I have attached the bios dump. I had read the chip next to the cmos battery (25q80jvsiq) then i realize that it wasn't the bios. as the bios is next the memory slot. By doing that could...
                                            04-17-2024, 09:27 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
