LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • Gunat360
    • Sep 2025
    • 3
    • United Kingdom
    #3941
    Originally posted by peste
    post S/N, full name and model, motherboard model, TYPE,etc.
    Thanks for the reply!
    P/N: SL10Q67064
    S/N: PF-1FC02J
    Lenovo ThinkPad-T480-TYPE-20L5-20L6
    Factory: JVHFC1
    MTM: 20L6S08H1A
    BIOS Chip: WinBond 25Q128JVSQ 128
    Advice on how to get motherboard model, as the system does not boot? Thanks!
    • fabian_457
      • Dec 2015
      • 3
      • mexico
      #3942
      HELLO!! Can you help me remove the password? I've tried lenovo_autopatcher but it doesn't work. Serial Number: PW-05DRJP MODEL: ThinkPad L14 Gen 3, LG4 LT5 ADL RT UMA MB 223030-1. 448.0PZ80.0011
      BIOS ATTACHED. THANKS, COLLEAGUES.
      • elianadragon
        • Sep 2025
        • 3
        Hello! I tried using the autopatcher for my Lenovo T480s, but it only causes the system to beep and display a blank screen (sometimes a very dimmed Lenovo logo). I'm using AsProgrammer and have followed the main instructions in this thread. I have also tried the W25Q128JV@SOIC8_PATCHED.bin file.
        I've attached my original bin file.
        Lenovo Thinkpad T480s
        TYPE NUMBER: 20LS-002CUS
        S/N: PC-0Y188A
        Bios: Winbond W25Q128JV5Q
          • 21307
          EC chip is NPCX997 ? https://www.badcaps.net/forum/troubl...95#post3592395
          • Karol
            • May 2016
            • 84
            • Romania
            #3945
            Are you sure you didn't do any faults to the motherboard ?
            Program back the backup, see if you have POST
            Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
            • Stefan Steff
              • Mar 2024
              • 289
              • Romania
              #3946
              S/N: PC-0Y188A
              OK, let's see if my method works for you...
              STEP 1: Flash and replace current BIOS with the attached Lenovo ThinkPad T480s_PATCHED.bin file
              STEP 2: Boot the machine
              STEP 3: Press ENTER/F1/etc. to enter BIOS settings
              STEP 4: Enter any character when asked for Supervisor Password
              STEP 5: Press enter when it shows Hardware ID
              STEP 6: Press space bar 2x when asked
              STEP 7: Turn off machine
              STEP 8: Restore your saved Original.bin BIOS
              STEP 9: Reset BIOS settings to factory default
              Good Luck!
              • dustin_echoes
                • Sep 2025
                • United Kingdom
                #3947
                Good Luck!
                I had the same issue as elianadragon when using autopatcher (T480s, S/N PC-1678ZZ, w25q128jv). I tried your patched version and worked perfectly. Thanks!
                • elianadragon
                  • Sep 2025
                  • 3
                  I've tried reprogramming the backup, and I can enter the BIOS again with that. The screen is still very dim with it. (might be backlight, but I am using a brand new screen)
                  • elianadragon
                    • Sep 2025
                    • 3
                    Good Luck!
                    Thank you for responding!
                    After I flashed this file, I pressed F1 and got four beeps. Then it shows a faint "Entering Setup" on the screen and hangs there.
                    • Stefan Steff
                      • Mar 2024
                      • 289
                      • Romania
                      #3950
                      Flash your original BIOS again and check if the laptp starts ok and you can get to the Password screen.
                      If it's ok then flash the patched file and try again all steps from the beginning
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
